changing intake manifold?
Old Nov 6, 2011 | 08:35 PM
Tim H's Avatar
Tim H
Originally Posted by billla
Automatically, huh? So what type of power increase do you expect to see from an intake upgrade on an otherwise totally stock engine? 1: weight reduction, 2: preparing for a Holley carb in the future.
Here's your report card from The Prof:
Engine operations theory and basic hotrodding.........F I get stuff done without researching 10 weeks because I have done it 25Xs before hand
Common courtesy and politeness...........................F- What do you want, someone asked a question and you answer with a question, on the other hand I give an answer....
Old Nov 6, 2011 | 08:40 PM
McVette's Avatar
McVette
Hmmmmmm ok lets all get along here guys.......LOL
Old Nov 6, 2011 | 08:42 PM
scottyp99's Avatar
scottyp99
Originally Posted by MotorHead
The only thing you might notice a difference from would be a free flowing exhaust. Unless the motor was a Christmas present buying a 195 HP motor and then asking what you should do to make more power, sorry just doesn't make any sense.
What you should do to make more power would have been to buy a 295 HP motor in the first place. Buy the time you get the 195 HP motor to 295HP you will have spent more money had you bought the more powerful motor in the first place
That's not necessarily true, if you know how to bargain hunt.
Scott
Old Nov 6, 2011 | 08:51 PM
scottyp99's Avatar
scottyp99
Originally Posted by McVette
Yea motorhead I would have done that IF I actually bought the motor but motor was in car when i bought car...the PO just keep records and such on everything done to car down to oil changes, wheel alignments to everything done to car for last 15 years...and i was just asking to see if it would possibly be any noticeable HP gain..thanks
.....LOL
It's a small block chevy, it'll pretty much respond to the usual hotrod stuff just about like any other smog era small block. Headers, intake, cam, heads if you get really ambitious. Don't listen to naysayers who think that your engine is somehow too inferior to ever make any power. Check this article out:
http://www.corvettefaq.com/c3/goodwr...20part%201.htm
Scott
Old Nov 6, 2011 | 09:03 PM
McVette's Avatar
McVette
Oh so there is hope after all......hehe
Old Nov 6, 2011 | 09:21 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by Tim H
{rant removed}
Actually, you never did.
I would like to know if there would be any possible HP gain by doing this.
If you have headers, there's probably around 15-20 FWHP available from an intake change. With stock exhaust manifolds, I'd probably give it a miss.
Where's your power estimate?
The worst kind of answers are "automatic" answers without knowing the variables...as they seldom produce good results...and show a basic lack of understanding of how to make power effectively vs. just bolting on parts.
'nuff said - I guess there's room on my <ignore list> for one more person.
Old Nov 7, 2011 | 07:28 AM
Tim H's Avatar
Tim H
Actually, you never did. My answer was an aluminum intake with a pic and description, what info did you tell him that was useful?
"Where's your power estimate?" Replacing slick wore out tires with new tires really doesn't need an explanation does it? Or do you have an "on line calculator" you could use to tell you traction will be realized with new tires?
The worst kind of answers are "automatic" answers without knowing the variables...as they seldom produce good results...and show a basic lack of understanding of how to make power effectively vs. just bolting on parts. And answering a question with a question tells people you can't make a decision without 99% of the answer being given to you first.
So person asks a question and I tell them an answer without dyno proof so its not an answer?
Old Nov 29, 2011 | 09:36 PM
McVette's Avatar
McVette
hey guys looking at this intake and was wondering if anyone might think that i would have any clearance issues with it, the motor in car is not orginal motor but it is a GM 350 crate motor, in case that might would make a difference.........http://shop.advanceautoparts.com/web...RPENGPAMS____#
Old Nov 29, 2011 | 09:42 PM
billla's Avatar
billla
St. Jude Donor '14
The Performer is pretty well documented to fit under the stock hood (search is your friend ), albeit often requiring a drop-base cleaner. It's one of the best low-rise, dual-plane intakes out there.
Old Nov 30, 2011 | 01:58 AM
Tim H's Avatar
Tim H
I'll buy any brand but Edelbrock, he has enough money already!
Old Nov 30, 2011 | 11:22 AM
Shark Racer's Avatar
Shark Racer
FWIW, when I had the GW350 installed in my motor, I also had a 3701 Edelbrock intake installed. (VS very original 1978 Corvette engine)
I couldn't honestly tell much of a power difference between the GW350 and the L48 it replaced, even though a lot of stuff was refreshed. There may have been something seen on on the dyno, but I didn't feel it.
Now, when I ditched the manifolds for 1 5/8" headers, that was night and day.
So, whether or not the intake contributed a lot after the exhaust, I can not say. I can say that if you do have to change the intake for any reason, I would much rather replace it with aluminum for the significant weight loss, improved look (IMO) and they can be ported much easily than an iron intake.
