PCV or not PCV
Old Nov 7, 2011 | 07:00 PM
Ghunt's Avatar
Ghunt
Default PCV or not PCV
My 68 327/300 hp has a Holly Double pumper, mild cam, headers with 2 1/2 " ex, roller rockers, tall valve covers, 9.6 to 1 comp.
There is no major leaks, no smoking, no smoking on start up.
I put a new pcv valve in and in doing so I pulled the gromet out and looked in the valve cover, no baffel but the gromet is like a deep plug with a slit in the bottom. I'm sure that oil is being sucked up through there. At idle looking in the valve cover there is a lot of oil being thrown around, no lack of oil in the top end on this puppy.
Could I just put a breather in place of the pcv valve, there is already one on the other valve cover, and would ther be any problems with that. I know that the pcv is part of the emissions but everything else has been taken off.
I did a search but got cross eyed reading all 200 threads and couldn't find a answer to this.
I'm sure that somebody here will have the answer.
George
Old Nov 7, 2011 | 07:39 PM
Gordonm's Avatar
Gordonm
Here you go. I asked this a while ago. You will get all kinds of answers. There is no right or wrong answer. I went ahead and ran one.
http://forums.corvetteforum.com/c3-t...ot-to-pcv.html
Old Nov 7, 2011 | 07:51 PM
htown81vette's Avatar
htown81vette
You definitely want to keep the pcv, I have been told it will enable your engine to last longer. Its more than just emissions.
Old Nov 7, 2011 | 08:00 PM
Marlin's Avatar
Marlin
Yea you want a baffle but if the VC does not have a baffle then look for a breather cap that has a spot for a PCV valve on top. That will help a little if you are sucking up to much oil.
Like this...
http://performanceparts.com/part/Trans-Dapt/4999
Old Nov 7, 2011 | 09:36 PM
Ghunt's Avatar
Ghunt
Thanks all, you'r right, There's many differant sides to to this simple question. I guess I'll find a set of tall covers with baffels and stick with the pcv.
One quick note, I was getting a little smoke at start up and the last oil change I added a 1/2 qt of Marvel. No more smoke just pcv sucking up my oil.
Thanks GHunt
To PCV or not PCV
