Shifter question for '74 Auto
Old Nov 8, 2011 | 11:45 AM
ClassicG's Avatar
ClassicG
Default Shifter question for '74 Auto
Hi, I currently have my '74 on blocks. I have removed the calipers and am deciding how to replace them. In order to get the key out of the ignition, I had to disconnect the 'interlink' connection at the engine side of the firewall, by removing the cotter pin and removing the washer. The key came out. Now, when I shift the car into neutral, the rear rotors will not spin. I don't yet understand the shifter assembly - when i looked at it, I noticed that it is pushing a rod through a sleeve. Is this rod what shifts the transmission gears, or is it the interlock connector to the steering column?
Old Nov 8, 2011 | 11:50 AM
Mike Ward's Avatar
Mike Ward
Your rotors won't spin because you're letting the suspension 'hang' and it's binding. Nothing to do with the interlock.
Old Nov 8, 2011 | 12:28 PM
ClassicG's Avatar
ClassicG
Thanks Mike, that makes sense.
To Shifter question for '74 Auto
