I'm ready to pour gas on this thing and torch it to end my suffering. I'm not going to talk about the four weeks that I've been working on my brakes. I'm not going to complain about the multiple parts vendors that have totally screwed up my parts orders in that time, adding to my aggravation. I'm not going to rant about the slow brake fluid leak that took me a week and a dozen hours to solve. I'm going to talk about my Spal fans that kept me in my driveway this weekend.
About when my brake marathon started, my Spals stopped working. I've checked the system from one end to the other. There is power to the relays, power to the plug at the base of the fans, they just won't run. I even took them off the car and tested them with a battery charger. They worked perfectly.
This isn't rocket science!
I'm at my wits end on this. Any suggestions before I drive it into the Bay?
What are you using to trigger the relays? If its a 1 wire temp switch, try grounding the wire at the temp switch to see if they turn on, if so, the temp switch is bad.
I've been using a wire to ground the sensors when the engine is cool. I think that the relays are tripping properly when the engine is hot, though that's harder to check. Still no fans.
How do you have it wired up? If connecting the negative side of the relay to ground triggers them, as mentioned by the poster above, it's your temp switch that's bad.
What part of the area are you at? I can probably help out.
So they work when you take them off the car?
And there is power right to the plug yet they don't spin?
its either the ground your using or they are hitting on something and stopping them from turning.
I'd be the wrong guy to call on the suicide hot line
But very early on my spal fans failed to come on and I and the vette boiled over. So I made the system simple. One came on with the ignition key and fan two got a manual switch
I think that I had a bad temp switch, but that did not matter since I was 30 miles from home and the quick fix from an auto parts store has worked flawlessly for about 4 -5 years
I'm in Pleasanton. Just look for the smoke and follow the sirens.
Just to clarify, the fans do not come on when I jump the sensors. The relays do click though. I was doing this to test if power was getting to the plug at the base of the fans. I have it wired up with two different sensors. I don't imagine both would fail.
Should've given me a call over the weekend Mike, I could have stopped by and helped out
Should have Randy, but by that time I was in a pretty crappy mood. It just seems to be the nature of this car to have really simple things that don't work right; or maybe the nature of the owner
If the relays are popping, have you verified your fan grounds and the two battery cables?
I'd suspect they have a common ground that is weak or completely failed.
There definitely is a single ground. It hasn't completely failed because my multimeter shows Voltage across the plug but I don't know how to assess if the ground is weak. That possibility did occur to me as both fans don't work and, other than the ground, the two systems are essentially separate.
Switch your multi meter to ohms and check, you should come up with zero's all the way across indicating no resistance.....I'm no electrical whiz but that's how I've always checked for a good ground
Where did you ground to?
If it's only grounding through the threads of a bolt, that may not be enough. If you're using a common ground that leads to an actual ground source, you may be overloading the wire leading back to the source.
Mine is grounded to the steering crossmember with a self-tapping screw.
What I'd recommend doing next is grounding the switch side of one of the relays to a known good ground, then run the ground of one or both fans to a known good ground. If they start working at this point, it would suggest either the switch is bad or the ground is bad.
I agree If you have power all the way to the fans. and the relay is closing(= relay power and ground are good) then the ground you are using for the fans is bad.
By probing for voltage on your ground wire your test light or meter is provinding the ground for the circuit.
Run a separate ground lead for each fan to 2 different ground points on your frame
I ran a separate ground to the radiator support. I think there are bolts between the frame and the rad support but I suppose you never know. I'll try removing that connection and grounding directly to the frame to see if that solves the problem. I'll give this a shot tonight and let you all know.
Hey Mike,
If all else tests OK, how about removing the relays and direct wiring through the sensor just to see if it/they kick in. Dont run it for long ...
Reason I suggest this is because the fans draw quite a load and sometimes the relay contacts get damaged by arcing when they open and close. Even though you may show the correct voltage at the plug, when the current draw kicks in it may be enough to stop it working.
Kind of similar to starters that appear to have the correct voltage but a poor ground causes high resistance etc etc
Always good to run a separate ground when installing hi amp accessories.
Thinking about it, if you connect your multimeter on the ohms scale across the relay outputs controlling the fan then apply power to the relay, see if the meter drops to 0 indicating relay is good.
I had a bad headlight relay on Pam's Ghia that was doing this....
Failing that, drop it off at the port and I'll pick it up at Southampton and sort it out for you....or you could fly me out as your personal electrician!
