battery problem/battery drain
Old Nov 14, 2011 | 12:18 AM
rzkas's Avatar
rzkas
Default battery problem/battery drain
Hi and how are you? i bought a brand new battery for my 82 corvette. installed it and car fired up at one turn. left battery in the car for a week. went today to start the vehicle, the engine turn but it can't start it. not enought juice or volt on the battery to start the car. the more i attempted to start the car the lesser the response i get from the engine. what could it be or what might be draining my battery? i dont have any hood or under hood light, no stereo or alarm. thanks
Old Nov 14, 2011 | 12:23 AM
Shark Racer's Avatar
Shark Racer
Gotta check battery drain from the negative post and pull fuses until it stops.
Old Nov 14, 2011 | 12:46 AM
OzzyTom's Avatar
OzzyTom
If you can't isolate the battery drain quickly, you could use a battery isolation switch.
Quite a few people fit a battery cutout switch to the battery terminal post.
It is a foolproof way of preventing battery drain on a car which is not driven regularly. Works for me.
Old Nov 14, 2011 | 01:40 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
My car can site for weeks at a time and I never have an issue with it ,,
so this may help
http://forums.corvetteforum.com/c3-g...with-pics.html
Old Nov 14, 2011 | 09:13 AM
Roughrider's Avatar
Roughrider
A possible and common problem could be the courtesy light timer. They seem to be a regular offender for this kind of problem after so many years.
When they go bad the courtesy lights (interior and spare tire lights), can stay on or turn on at random times and drain the battery. The way I found out the timer on the '78 I used to own was happen to be up late and looked outside and saw the interior lights on in the car. That explained why I kept having a drained battery. I changed that and no more problem.
The timer is a bright orange piece mounted behind the glove box with wires plugged into it.
Old Nov 14, 2011 | 01:26 PM
rzkas's Avatar
rzkas
good ideas. thanks and i will try them.
Old Nov 15, 2011 | 12:55 AM
my 76 ray's Avatar
my 76 ray
Were you having problems before replacing the battery? It could be a defective battery or dirty battery cable connections.
Old Nov 15, 2011 | 10:49 AM
rzkas's Avatar
rzkas
Yes it because of that reason i went and bought a brand new battery.
at one point in time, i thought it was the old battery but it still happening with the new battery
Old Nov 15, 2011 | 11:28 PM
rzkas's Avatar
rzkas
hi? i did tester light test. the test light stay on for open door and close door. i need serious help. where should i start to fix my electrical issues
Old Nov 16, 2011 | 12:00 AM
Roughrider's Avatar
Roughrider
It does sound like a bad courtesy light timer. The lights should go out no more than about thirty seconds after closing the door. If they stay on, look at the timer as the problem.
Old Nov 16, 2011 | 09:50 PM
Steve COSD's Avatar
Steve COSD
I have an 82. I had the same problem. Mine was caused by the alternator.
To battery problem/battery drain
