Brake line Routing
Old Nov 14, 2011 | 04:03 PM
bigvette1's Avatar
bigvette1
Default Brake line Routing
Ok, I forgot and have that disease of CRS. Anyway, does the rubber brake line run over the top of the spindle by the ball joint or under behind to the caliper. Looked in the AIM and not real diagram and a search turned up nothing,. Thanks
JP
Old Nov 14, 2011 | 04:48 PM
MelWff's Avatar
MelWff
hard to picture what you are describing but the hose has to have enough play to move freely through the complete up and down movement of the spindle/caliper
Old Nov 14, 2011 | 05:44 PM
Alan 71's Avatar
Alan 71
Hi bv,
The hose runs from the hard line connection on the side of the frame directly to the caliper. So it passes to the rear of the spindle and below the upper ball joint.
Mel's right, it needs to have enough legnth for steering travel, so can only really be mounted in one way.
Hope this helps!
Regards,
Alan
Old Nov 14, 2011 | 06:00 PM
redman76's Avatar
redman76
St. Jude Donor '09
Ditto the above comments. Here is the only pic I could find . . . mine are the braided steel type hose.
To Brake line Routing
