Fuse Block Ignition Lug -- Capacity?
Old Nov 15, 2011 | 01:10 AM
Postal123's Avatar
Postal123
Default Fuse Block Ignition Lug -- Capacity?
All,
I'm wanting to run the following wires to the ignition lug:
1-12ga to Coil+ wire (Mallory coil with magnetic breakerless dist).
2-ignition fan relay wires (Dewitts dual w/main pwr wires to starter block).
1-ECU ignition signal/relay wire (Power Jection III w/main pwr direct to Batt+)
This terminal will be adequate for the load, correct? Also, it looks like this lug is protected by the 'DIR SIG' 'BACKUP' 20 Amp fuse...correct?
Do you recommend a different approach?
Thanks,
Rob
Old Nov 15, 2011 | 05:03 AM
dembo's Avatar
dembo
Well, I had similair setup with Powerjection, electric fan, HEI and aftermarket stereo setup but added a painless cirkit boss in the jack tray, powered from the battery, tripped by a ign wire. : http://www.painlessperformance.com/w...l=Classic Cars
You keep your car's wiring original & it avoids extra strain.
Might be a consideration
Nick
Old Nov 15, 2011 | 05:14 AM
7T1vette's Avatar
7T1vette
I'm not certain about the load carrying ability of 'open' terminals on the fuse block. The only item that is questionable is the one related to the radiator fans; those absorb a lot of current when running. I would think those would be better run to the + power lug on the alternator or directly to the + terminal on the battery, with a circuit breaker (of appropriate size) placed in that line.
Old Nov 15, 2011 | 06:34 PM
Postal123's Avatar
Postal123
Thanks for the responses. 7T1vette, I'll order one up. Where did you install?
r,
Rob
To Fuse Block Ignition Lug -- Capacity?
