69 speedo acting wild
Old Nov 16, 2011 | 05:12 PM
Crahm's Avatar
Crahm
Default 69 speedo acting wild
My new-to-me 69 speedometer bounces wildly in the 60-150 mph range at speeds less than 40 (est). Above that, it just stays pegged high.
Cable problem? Instrument problem?
Incidentally, the odometer works.
Charles
Old Nov 16, 2011 | 05:30 PM
MelWff's Avatar
MelWff
my guess, speedometer problem. Do you know if anybody tried greasing the cable, if done incorrectly causes speedo problems.
Old Nov 16, 2011 | 07:47 PM
terry82's Avatar
terry82
lube the cable .check the ends they can round off.
Old Nov 16, 2011 | 10:07 PM
bugzbunny's Avatar
bugzbunny
69 Coupe has two cables, not counting the tach
Old Nov 16, 2011 | 10:52 PM
joewill's Avatar
joewill
my 'new' one from the vendor, bounced wildly from 0-70 while rolling down my driveway. if I stopped at the right point it would stay at 70.. until I then rolled a little more then it dropped to zero...
I sent it back and then received another new one that worked OK but the odometer ones and tens would stick together.. effective going 100 miles per every 10.. I sent it back and then had my original one rebuilt and all is well..
i merely state this to advise you to get your old one rebuilt and not buy a new one...
To 69 speedo acting wild
