Cruise control
Old May 7, 2002 | 03:59 AM
Ingar, Norway's Avatar
Ingar, Norway
Default Cruise control
I just cant get my cruise control to work properly. It seems to have far to much amplification and speed oscillates wildly around the setpoint, making it useless.
Is there a fix for this problem?
How is your cruise control working?
Old May 7, 2002 | 05:03 AM
Scott78's Avatar
Scott78
Default Re: Cruise control (Ingar, Norway)
Mine works fine. There is the transducer which the speedometer cables go thru and it controls vacuum to the servo. More then likely the transducer is going out. Another possibility is a vacuum leak in the servo. Both parts are available thru Zips or your favorite vette parts supplier. Sorry I don't know of any testing procedure on the transducer, on the servo you could pull a vacuum on it and check for leaks. Good luck
Old May 7, 2002 | 09:36 AM
Neo Fender's Avatar
Neo Fender
Yep, the transducer is probably binding internally. Evantually, you may begin to experience problems with your speedometer or speedometer cables.
Old May 7, 2002 | 11:25 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I know of guys on this forum, who bought their cars new. And from day one, the cruise acted strangely. Others say theirs have always worked fine.
Mine will engage, most times. And it might hold for a mile. But sometimes, it will take off like a batt out of hell. Other times, it just cycles, up and down. I haven't done anything with it yet. But I will.
Good Luck with yours!
Old May 7, 2002 | 12:04 PM
tangee-vette's Avatar
tangee-vette
I also had a bouncing speedo needle along with a cruise control that refused to hold steady. Just replaced my transducer and both problems disappeared. :yesnod:
Rick :cool:
Old May 7, 2002 | 01:56 PM
Ingar, Norway
Thanks!
I have checked that the clutch mechanism is operating freely. Have even bench tested the unit and it seems to work normal.
The problem is that it adjusts the actuator vacuum far too much, just as a control system with too much amplification.
I understand it must be a transducer problem, but I would like to find the cause and fix it. No replacements are available over here.
(When I started working on this I made an "analysis" of the operation, have article on that at my page)
Old May 7, 2002 | 02:00 PM
Neo Fender's Avatar
Neo Fender
Try locating a used one. Do you have access to any wrecked GM vehicles there? The cruise control transducer is common to many GM vehicle platforms, not just Corvettes.
[Modified by Neo Fender, 12:01 PM 5/7/2002]
Old May 7, 2002 | 03:49 PM
slaine's Avatar
slaine
I'd need to look at my transducer to be sure, but it seems to me that the transducer has a threaded brass tubing where the vacuum hose connects. The fitting has a jam nut on it. You can loosen the jam nut and screw the brass fitting in and out of the transducer. Moving the fitting in or out can adjust fluctuations. I think that there's a hole that's covered and uncovered by turning the fitting, controlling the vacuum rate and signal from the engine.
Make sure that you're using manifold vacuum and not carb vacuum(not likely, but it's something to check).
Like a lot of people, I like to see how far I can drive on cruise-control without touching the brakes. And, no, it doesn't take much to amuse me when I'm driving my vette.
Good Luck, Mike :)
Old May 8, 2002 | 12:50 AM
tangee-vette
I've seen NOS and rebuilt transducers on ebay quite often. There is a used one currently listed;
http://cgi.ebay.com/ebaymotors/ws/eb...219334&r=0&t=0
Rick :cool:
To Cruise control
