Broken Motor Mounts
Old Nov 22, 2011 | 10:37 AM
DaveL82's Avatar
DaveL82
I've had numerous types of non solid motor mounts break over the years. Always made sure I put the cross bolt from the side that allows me to remove it easily.
I now run nothing but solid mounts. While they add a bit of vibration and noise it's not bad at all so one of the cheapest performance improvements. It tighten up the chassis so another big plus.
Old Nov 22, 2011 | 11:05 AM
The Money Pit's Avatar
The Money Pit
Originally Posted by gkull
They are a PITA to change with the motor installed. So it might have been telling me to just pull the motor out now.
I think that the 335 rear tires hook too hard when conditions are just right
These are Moroso solids. I can't say I noticed any additional vibration,...but my cam shakes the car anyway.
So,....is it out yet? I just love to see the engine hanging on the picker!
Old Nov 22, 2011 | 12:51 PM
gkull's Avatar
gkull
Originally Posted by RobbSalzmann
Those are the ones I've been using through the years.
So which one do you really use Robb and Dave say Moroso 62500 - Moroso Solid Motor Mounts or the slightly larger Moroso 62530 - Moroso Solid Motor Mounts
I have the 62530
Old Nov 22, 2011 | 01:30 PM
DaveL82's Avatar
DaveL82
To be honest I don't recall the part number as it's been a long time. I probably got them from Summit.
Old Nov 22, 2011 | 01:36 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
I have the 62530
Hmm, maybe you can help me figure that out:
62500 thickness = .25"
62530 thickness = .188"
I think it looks like I have 62500's
Old Nov 22, 2011 | 01:48 PM
gkull's Avatar
gkull
They have the hole and widths different. Robb a caliper is a better way to measure
Old Nov 22, 2011 | 01:56 PM
RobbSalzmann
St. Jude Donor '12
Yeah, but the caliper is in the other toolbox, all the way over there...
Old Feb 28, 2012 | 08:24 PM
ignatz's Avatar
ignatz
gkull: I would like to verify that you actually broke the energy suspension motor mounts. I called them before I installed a new motor and they claimed that they had a "patented interlocking mechanism" that would prevent the motor from over rotating so I went ahead with that assurance. Now ... I am not so sure that was good enough.
I had previously broken the stock mounts and the only clue was a little nick in the upper radiator hose. Now how did that get there I wondered? Holy Sh.., that's pretty scary, once I figured out the fan was hitting the hose.
Right now the body is off and it is relatively easy to do the right thing
Old Feb 28, 2012 | 08:36 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I just use one solid mount, on the drives side, so the motor doesn't lift as you gas it every once in awhile.
Old Feb 28, 2012 | 10:30 PM
Duane4238's Avatar
Duane4238
As far as the old chain rig goes for limiting engine movement, that wasn't really a "Bubba" trick. GM used it back in 1967. I had a '67 Camaro SS350 that got a recall for bad mounts. Took it to the dealer and they attached a kit that had a mount that went over the engine mount and was then secured with a short cable with an eyelet crimped on each end. When I changed the mounts, myself, I saved the kit and still have it on the shelf somewhere. It was a weird contraption. Would have been easier for Chevy to just change the mount.
Duane
Old Feb 29, 2012 | 12:11 AM
ignatz's Avatar
ignatz
I did a little more exploring on the energy suspension website and found this picture of their mounts showing the internals
I have what they call here the early style. It looks like one U shaped bracket is locked around another at right angles. This would seem to be pretty safe so I remain curious as to how they broke and whether I should be concerned.
Old Feb 29, 2012 | 12:22 AM
gkull's Avatar
gkull
I did not throw it away. The ES poly locking was kind of melted and is totally lose. it was the drivers side and allowed the motor to come up. It never came apart. I has approx a 1/2 inch to 3/4 inch pull apart n my hands.
It is enough engine movement to lift my headers into the steering rag joint
Old Feb 29, 2012 | 11:34 AM
  #33
ignatz's Avatar
ignatz
That alleviates my concern that there's a serious safety issue. I was going to pull them out and insert a bolt but I don't think that improves anything. I would mail the mount in to their tech guys and if they are at all responsible they will figure out why this happened.
thanks for the update!
Old Feb 29, 2012 | 07:01 PM
  #34
BB68Vett's Avatar
BB68Vett
I have a big block with headers and run ES poly motor mounts. After my drivers side melted I bought the motor mount shield intended for vehicles with air conditioning. I installed the shield on the driver side along with a fresh motor mount, a few years later I noticed the passenger side was melting too, so I bought another shield and installed it and a fresh mount on the passenger side too. This has totally solved the melting/softening issue.
Old Feb 29, 2012 | 08:36 PM
  #35
ignatz's Avatar
ignatz
Thanks BB68, I think you just saved me some future grief. I didn't know such a part existed but I found one at CorvetteAmerica. If the factory created such a part I have to assume they did it to fix an ongoing problem. To use that part I'd have to lift the motor a bit to install the mount.
But .. take a look at my situation
This is an LS3 iron exhaust manifold and it really is pretty close to the mount. Conveniently there is a threaded tab as part of the manifold that already holds an outer shield. Looks like all I have to do is put a shield on the inside similar to what GM provided. I can probably use that machined boss on the block for additional support. The passenger side is pretty similar.
Alternatively, the MM through bolt has the nut on the backside and I can fashion a shield to mount there. I'll play with it and see what looks best.
Cool (literally) and thanks
