Broken Motor Mounts
Old Nov 20, 2011 | 03:34 PM
gkull's Avatar
gkull
Default Broken Motor Mounts
I didn't think that it was possible to break "Energy Suspension" poly locking motor mounts. My Hooker supercomp headers saved me from real problems. I was doing some max effort launches and my steering became very difficult when I had my foot on the floor. The motor rotated up and the header pipe would wedge against the steering rag joint.
I was just screwing off because the motor is a couple of years old and I was going to pull it and refresh it this winter
So I stopped by Summit racing and bought Morroso solids
Old Nov 20, 2011 | 04:28 PM
billla's Avatar
billla
St. Jude Donor '14
If you weren't so good at building power, you wouldn't have these issues
Any carnage shots? :-D
Old Nov 20, 2011 | 04:40 PM
gkull's Avatar
gkull
They are a PITA to change with the motor installed. So it might have been telling me to just pull the motor out now.
I think that the 335 rear tires hook too hard when conditions are just right
Old Nov 20, 2011 | 08:58 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Been running the solid Moroso's for 10 years now without issue
Old Nov 20, 2011 | 09:56 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
What are the positive and negative effects of solid mounts?
Old Nov 20, 2011 | 10:02 PM
SIXFOOTER's Avatar
SIXFOOTER
Positive is they don't break, negative is a little more engine vibration to the frame
Old Nov 20, 2011 | 10:09 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Thanks for allowing your setup to be used as the mule for torque testing those mounts, gkull. That's a big footprint so no wonder there's enough patch to absorb all that twist.
Old Nov 20, 2011 | 11:57 PM
Bowerss2's Avatar
Bowerss2
a little more???
Old Nov 21, 2011 | 10:48 AM
gkull's Avatar
gkull
In Energy Suspensions defense. The motor mounts are about two years old and a 5 speed tranny with a lite weight flywheel is probably really abusive.
Old Nov 21, 2011 | 12:31 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I have a set of these and I just noticed that one is melting a little...
guess ill have to changing mine soon too....
Old Nov 21, 2011 | 05:24 PM
Blue Juice's Avatar
Blue Juice
gkull,
You are following the exact issue I had a couple of years ago.
I bust a 6 month old Poly mount and even before it let go I used to have problems with my supercomp headers contacting the rag joint under hard acceleration.
I moved to solids and wish I had done so years ago.
I don't notice any downside or increase in vibration in the car, but it feels great when you hit the gas. I know that there is absolutely no effect on power, but everything feels "tighter" and more "alive". Sounds naff, I know, but swap to solid mounts and you'll see what I mean.
I still have a rubber mount on the transmission (TKO600) and have run this way for about 2 years with no problems.
Old Nov 21, 2011 | 06:00 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've broken OE mounts before, but this surprises me. In any event, the Moroso solids have served me well for many years, and I will even more highly recommend them for high-perf applications from now on.
FWIW, in addition to a spreader, upgrading to solid mounts stiffens up the front end further still.
Old Nov 21, 2011 | 08:25 PM
Ralphbf's Avatar
Ralphbf
We use to drill our motor mounts and put a 3/8 nut and bolt through them.
That way breakage was not an issue.
Ralph
Old Nov 21, 2011 | 08:37 PM
gkull's Avatar
gkull
Ralph
My buddy was over laughing and told me a good mechanic would have a chain on the drivers side securing the motor! The big bolt sounds even better
Old Nov 21, 2011 | 11:12 PM
billla's Avatar
billla
St. Jude Donor '14
Oh...I have pictures of one of these bubba jobs. I have a pretty firm rule that I don't do R&R on engine builds...but I had a buddy that called me and wanted a build, and asked me to PLEASE help. Found a chain welded to a piece of angle iron bolted to the block, and the PS pump was bolted to a piece of angle welded to the frame.
Needless to say, that was just the beginning of the fun with that build. I also ended up with a 2' diameter ball of wire cleaning up electrical issues. That's what I get for breaking my own rules
Old Nov 21, 2011 | 11:20 PM
TheSkunkWorks
I've done the chain thing back in the day. Ain't pretty, but done properly it does work.
Old Nov 21, 2011 | 11:31 PM
Cactus Dave's Avatar
Cactus Dave
Anyone post a link for the Moroso solid mounts?
Edit: Would these be the ones? http://www.jegs.com/i/Moroso/710/625...oductId=744093
To Broken Motor Mounts
Old Nov 22, 2011 | 12:45 AM
gkull's Avatar
gkull
C dave this is what Summit gave me for my 79
http://www.summitracing.com/parts/MOR-62530/
Old Nov 22, 2011 | 12:50 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Ever try the 1/4-20 bolt through the mm George? Works OK for me but i've never had a 500hp hi po motor.
cardo0
Old Nov 22, 2011 | 10:02 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Those are the ones I've been using through the years.
Although I don't use any "pads" with mine.
