ZZ4 Engine
Old Nov 23, 2011 | 10:22 PM
toupstrio's Avatar
toupstrio
Default ZZ4 Engine
I have a zz4 engine that I am going to put in a 72. I have the hooker headers with side pipes. Will these headers fit my zz4 heads?
Old Nov 23, 2011 | 10:52 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
The ZZ4 heads have a D exhaust port, I matched that up with my hookers when I ordered them. Does your existing hedders have a D post flange?
Suggestion: Call Hooker and ask, they should be able to tell u PDQ.
Old Nov 24, 2011 | 12:38 AM
cv67's Avatar
cv67
St. Jude Donor '05
Sure they will they just have to cover the ports and they are small on those heads. Doesnt have to match just cover thats all.
Old Nov 24, 2011 | 01:29 AM
Ralphbf's Avatar
Ralphbf
I have ZZ4 heads on my 75 with Summit's 1 5/8 headers.
The "D" shaped ports are a lot smaller than the header flange.
So no problems man.
Ralph
One more thing I'm very happy with the ZZ4 heads.
I'm putting out close to 335hp with a stock block and Lunati's 102 cam.
with a stock auto tranny and converter.
Dual exhaust is a must. Some say it's worth 50hp.
Old Nov 25, 2011 | 11:07 PM
toupstrio's Avatar
toupstrio
Thanks to all for the reply's
So no problems man.
Ralph
Old Jan 24, 2012 | 11:34 PM
Chris1357's Avatar
Chris1357
7th Gear
I just purchased a ZZ4 engine to put into my '73 and would like to go the sidepipe route. Did your hooker sidepipe headers fit with the ZZ4 angled plug heads or did you go back to rear exhaust? I phoned Hooker today and they said the headers wouldn't fit. Thanks
Old Jan 26, 2012 | 01:39 AM
MakoShark72's Avatar
MakoShark72
Absolutely..
Old Jan 26, 2012 | 09:38 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Not sure the ports, but on my ZZ4 I was using Hooker Supercomps. The none sidepipe ones and they worked fine. The header tube was bigger than the port and the angle plugs did not have any issues.
To ZZ4 Engine
