Motor mount
Old Jan 26, 2012 | 11:06 AM
JER BEAR's Avatar
JER BEAR
Default Motor mount
NEED TO REPLACE MOTOR MOUNT ON DRIVERS SIDE, HAS POWER STEERING, 350 SMALL BLOCK 73, PICTURES , SITES, ANYTHING TO MAKE IT EASIER. THANKS
Old Jan 26, 2012 | 11:11 AM
damoroso's Avatar
damoroso
Easier than what? It's pretty straight forward, us a jack to support and lift the engine if you can, pull the through bolt, loosen the three mount bolts, lift the engine enough for the mount to clear the frame, remove the mount bolts and pull the mount. Reverse to install...
