TH400 question
Old Nov 23, 2011 | 10:31 PM
Xterrable's Avatar
Xterrable
Default TH400 question
I have a 1974 Convertible that I am learning more and more about as I start to pull the motor for a rebuild. From driving it, I knew it was a 3-speed auto.
For some reason, I thought it was the Hyrda-matic 350, but now that I have the pan down, I see that it is not... It is actually a TH400... What transmissions came in the 74's?
I dont know much about this transmission. Is it a good tranny? My goal with my engine rebuild is to get 315-350 HP out of the 350 with intake, carb, heads, cam, exhaust upgrades. It the TH400 up the job?
What are your suggestions on rebuilding it? My buddy is a mechanic and said we can do the basic maintenance to it ourselves. It drove fine when I parked it this fall. I am on a budget, so what are your suggestions. Pull it with the motor? Leave it in there and just drive it till something goes wrong?
One thing I did notice is that the pan has been repaired once before. There is an outward dent in the pan that someone filled in with brass.. All I see for replacement pans are chrome ones. Are they reliable? Does anyone make a stock depth aluminum one that will help with cooling?
Thanks for the info..
Old Nov 24, 2011 | 07:50 AM
Roco71's Avatar
Roco71
I am not a expert by any means but believe all 74 and 75 had Th400 in them. The 400 is a pretty much been said to be "Bullet proof" very durable and can handle up to 400HP stock. The biggest drawback that I have heard is that they suck horse power to operate. If you are on a tight budget and it was working OK I would look at maybe just replacing the seals. I have read that some of the aftermarket aluminum pans require a spacer to clear the heaver lip in order for the shift cable bracket to fit correctly.
Old Nov 24, 2011 | 10:17 AM
JimT's Avatar
JimT
It's a good transmission. Don't buy a chrome pan, buy a cast aluminum one with a drain. And, you will need a spacer for the shift cable bracket. I use a thin paper gasket for sealing the pan - get one from a trans shop, and do not use any sealant.
Be careful tightening th pan bolts! The tanny housing is aluminum so the threads can easily be stripped.
Old Nov 24, 2011 | 11:18 AM
willem wallace's Avatar
willem wallace
Default Turbo 400
These are tough transmissions and work well in their stock configuration for cars in your projected horsepower range, without modification. I have put one behind my stroked small block and modified it slightly with a shift kit and higher stall torque converter, to take advantage of the increased power curve of my new engine. One other modification I made was to install a truck( these 400's came stock in GM pickups, cheap boneyard upgrade!) oil pan, which is deeper and allows for more fluid, which I felt made sense in a high performance application. I plan to add an external cooler, too. You may or may not realiize, also, that the stock rear end gearing from the factory with the 400's, was a 3:08. I upgraded to the performace option rear gearing, which is 3:36, and can be found everywhere for these cars, very cheap, to give you an economical boost in the seat!
Good Luck!
Willem
Old Nov 24, 2011 | 11:43 AM
Xterrable's Avatar
Xterrable
Never had much luck with chrome accessories. They always seem to be made cheaply.
I was shocked at how loose my pan bolts were. They were not much more than hand tight.
So what are people using for spacers? I saw where some say that the factory bolts were to wide and they needed smaller headed bolts. Will washers work for the spacers?
Old Nov 24, 2011 | 12:23 PM
Xterrable's Avatar
Xterrable
Never though about doing rear. How hard is it? What I want is more off the line power! I see sets on eBay for 300ish. Is that all I need?
Old Nov 24, 2011 | 02:16 PM
Ironcross's Avatar
Ironcross
a T400 can handle almost any thing you could attach it too and way more than the posters projected horsepower......and a positive note, there the way to go if you need a quick Vette......
And on this subject of modifications, why or what is the subjective mentality of people that will buy a Vette and almost in the same breath have to change most of the parts.......never could figure that out.....
Old Nov 24, 2011 | 03:20 PM
Cruisin Davey G's Avatar
Cruisin Davey G
TH400's tend to run a little 'warmer' temperature wise, so U may want to consider making sure your cooler part of the radiator is not plugged up & think about running a small external 'cooler' in front of the radiator.
If you really want to know how to tell if that car came with a TH400 or a TH350. Remember this, the TH350 comes with a manual 'kick-down' cable mounted to the carb linkage, whereas the TH400 has an electronic 'kick-down' switch mounted on the gas peddle linkage inside the interior, right near the firewall.
If someone were to put a TH400 into car that originally had a TH350, thay'd have to add this switch. Not too many will go through the trouble to do this. If the car was a TH400 & there is now a TH350 in it, chances are this switch, although disconnected, will most likely be still mounted in the car, where I said.
But, the '74 auto's came with TH400.
Old Nov 24, 2011 | 03:48 PM
Xterrable's Avatar
Xterrable
Great info guys.
As far as the gearing, is the ring and pinion all that I need? Also, what are you thoughts on the gear. Some say I won't see much of a difference with 3.36. They say go with a 3.55.".
Old Nov 24, 2011 | 06:08 PM
willem wallace
Default 3:08
If you get rid of the 3:08's, I may be interested.
Old Nov 24, 2011 | 07:17 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Have TH400 in my 75 with a shift kit, has lasted 37 years. 3.08 rear gear
B/M deep pan adds two more quarts fluid. Had a trans cooler on but didn't think it helped.
Old Nov 24, 2011 | 08:50 PM
Cruisin Davey G
Originally Posted by Xterrable
Great info guys.
If you start goin with taller gears, remember the gas mileage goes down unless gas mileage is not a concern.
What ya should do is toss in an OD trannie
Like a later 700R4 with the better front pump. Then you can 'bump' the gear ratio up to 3.73 & 'leap' off the line, but be able to 'cruise' a much lower RPM's, saving the engine wear & tear.
Even though the 2004R is just about a direct fit into the vette, that has a TH400, it doesn't have a lower 1st gear as the 700R4, but 2nd & 3rd, are 'closer' ratioed.
I put a 700R4 in my '72. There's more kits out there today, than a couple of years ago, to make it fit nicely, without too much 'hacking up'
Many places now make a real nice rear trans mount that fits nicely to the crossmember.
Either way, OD trannies are a good choice
Cruisin' Davey G !
Old Nov 24, 2011 | 11:28 PM
Rally68's Avatar
Rally68
Great info guys.
I swapped my 3.08s for 3.73s. US Gears from Tom's Differentials, highly recommend them. I bought a different brand first and didn't like the looks of them, the US Gears R&P were easy to pattern and have been very quiet. Besides the gears you will need a diff rebuild kit (bearings, races, seals, shims etc).
I agree with the recommendation to get an aluminum pan; you will need to get two longer bolts for the shift cable bracket, and you will need to modify the bracket to get it to fit--I ground the bolt holes open so I could mount the bracket in the stock location using the aluminum pan. You'll see what I mean if you install an aluminum pan.
Old Nov 25, 2011 | 09:53 AM
Xterrable's Avatar
Xterrable
Thanks for the recommendations!
I wish I had a lift at home. This car is a P.I.T.A to work under. Even up on car ramps, you dont have very much room under there.
As far as mileage, everything is a concern. Budget, drive-ability, gas mileage. But the ability to put a grin on my passengers face (and mine to) is rated pretty high.!
Old Nov 26, 2011 | 04:28 PM
pricesgarage's Avatar
pricesgarage
i like 700s and 200r4s in classic cars shift works sell gearshifter conversions to make it nice if u use the stock th 400 use a no walk case bushing a stock rebuild kit is all u need but get some thicker steel clutches to reduce clutch pack clearence new pupm gears are cheap so replace them and use a teflon coated pump bushing repace the wave clutches with flat steels i use a band m kit in all 400 so i can have a new seperator plate install all the check ***** drill the feed holes and remove the 2 3 accumulator spring and replace the kick down soleniod and a red stripe modulator that combo willl make a 400 shift fim but not agressive and last for a long time
To TH400 question
