suspension question??
Old Nov 26, 2011 | 12:52 PM
Mikeylikesit79's Avatar
Mikeylikesit79
Cruising
Default suspension question??
my suspension appears to be (offset?) with the entire suspension being 1.5-2inches heavy on ( or to) the passenger side if you are looking at it from the front, The car has to my knowlege never been wrecked the frame is straight and there has not been a full body off restoration that could account for misplacement of the body to the frame???? could there be some type of modification that I am not aware of that could explain this?? Or is there some suspension tuning trick that I could re allign the wheels with?
Old Nov 26, 2011 | 03:13 PM
MelWff's Avatar
MelWff
If you are saying the problem is the body in relation to the frame, check your body mounts.
Old Nov 26, 2011 | 05:09 PM
sly vette's Avatar
sly vette
One of two items is not level....The frame or the body. Check to see which one it is and get back to us.
Then you will get lots of help!
To suspension question??
