windshield wiper spray hose?
Old Nov 25, 2011 | 11:58 PM
glarior's Avatar
glarior
Default windshield wiper spray hose?
Where does the hose go from the windshield wiper pump? Mine has never worked and time to make it work. I am replacing the pump but there is no hose connected and I can't find where it would spray on the windshield.
Old Nov 26, 2011 | 01:24 AM
gbvette62's Avatar
gbvette62
What year do you have?
68's spray from 2 nozzles installed in the wiper grills. Later years had "wet arm" set ups with either rubber hoses going to brass tubes attached to the wiper arms, or hoses that ran up the arms, to plastic nozzles at the end of the arms, depending on the year.
Old Nov 26, 2011 | 01:39 AM
glarior's Avatar
glarior
Its a 80'
Old Nov 26, 2011 | 12:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by glarior
...Its a 80'...
AIMs are wonderful things.
Old Nov 26, 2011 | 12:26 PM
glarior's Avatar
glarior
Omw, I forgot all about the assembly manual. Haha. Thanks for reminding me I have one!
Old Nov 26, 2011 | 02:41 PM
gbvette62's Avatar
gbvette62
Your 80 will (or should) have the wiper arms that the rubber hose runs up. Each arm will have a small black plastic nozzle, at the end of the arm, where the blade assembly attaches.
The hose routing is pretty simple on the 80. Both hoses go through the firewall, into the cavity where the wiper transmissions are, and run up to the arms.
Old Nov 26, 2011 | 03:18 PM
glarior's Avatar
glarior
What's this... where my finger points. The hose to.the wiper connects to what ever that is.
To windshield wiper spray hose?
