Cam button or not
Old Nov 27, 2011 | 02:35 PM
no4n4me's Avatar
no4n4me
Default Cam button or not
Hey guys me again with yet another timing question.
I put in a Lunati retro fit roller package. I was going to use gear drive timing but went with Lunati double roller chain. Do I need the use of a cam button then?
I have been told both ways but am totally
Here is a video link
Thanks again! I really appreciate the help and opinions that I get here!!
Old Nov 27, 2011 | 03:09 PM
DRIVESHAFT's Avatar
DRIVESHAFT
You use a button when you run a roller cam.
Old Nov 27, 2011 | 03:22 PM
billla's Avatar
billla
St. Jude Donor '14
Yep, a roller *requires* a cam button to prevent cam walk.
Old Nov 27, 2011 | 06:40 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Don't forget to fold those metal tabs up snug to your bolt heads.
Old Nov 27, 2011 | 07:34 PM
mikep3's Avatar
mikep3
Looks like the large diameter goes in first then the lock plate holds it in.
Take the lock plate off and install the button.
Old Nov 27, 2011 | 08:03 PM
7t9l82's Avatar
7t9l82
there is a taper on flat tappet cam lobes that is not necessary on roller cams. so with a roller cam yes you will need a button.
Old Nov 27, 2011 | 08:30 PM
tt 383's Avatar
tt 383
Do you have a bearing/wearplate under the timing gear?
Old Nov 27, 2011 | 08:37 PM
speedreed8's Avatar
speedreed8
remove the 3 bolts that hold that lock plate on, remove the lock plate, insert the roller button, large end goes toward cam, reinstall lockplate and bend at least one of the tabs up against each bolt head flat, I'm running the same lunati chain w/wearplate setup and roller button on my 355 w/ retrofit roller.
Old Nov 27, 2011 | 09:21 PM
no4n4me's Avatar
no4n4me
Thanks a million times over guys!
Yes there is a bearing plate on the backside of the cam gear.
Removed the lock plate and it fits much nicer.
Thank you all so much for the help.
To Cam button or not
