which heads?
Old Dec 2, 2011 | 03:18 PM
tyancey00's Avatar
tyancey00
spend 4000 for a 383 stroker from a good engine builder and just drop it in. you will be much better off.
Old Dec 3, 2011 | 08:59 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I have a pre-1995 2101 (dual bolt pattern) intake on my car. I thought I had read somewhere that a square bore Holley would not work with a 1/16" thick adapter plate. Just for an experiment, I bought a spreadbore - squarebore adapter plate and mounted my new Holley Street HP 650 DP. It worked! Only adjustment thus far was turning in the idle speed screw about 3/4 of a turn. The new carb will be going on my new Team G 7530 intake very soon. So, for the OP, a squarebore Holley will fit a spreadbore 2101 intake in case you were considering going that route.
