Headers and side pipes
Old Dec 1, 2011 | 12:53 PM
bugzbunny's Avatar
bugzbunny
Default Headers and side pipes
I received the headers and side pipes , oh man do they look great. I just have one question, why is there a hole in the driver side header?, is this for air to escape?
Old Dec 1, 2011 | 01:00 PM
larryg3's Avatar
larryg3
probably for an O2 sensor. what brand of headers and side pipes did you get. I actually had to drill mine and weld a bun to add my O2 sensor
Old Dec 1, 2011 | 01:04 PM
bugzbunny's Avatar
bugzbunny
got the ones here from Josh for 900. What is an o2sensor?
Old Dec 1, 2011 | 01:11 PM
blckslvr79's Avatar
blckslvr79
Oxygen sensor for a computer.
IF you have no computer, by a plug and fill the hole.
Old Dec 1, 2011 | 01:14 PM
bugzbunny's Avatar
bugzbunny
oh man, what kinda plug?
Old Dec 1, 2011 | 01:41 PM
larryg3's Avatar
larryg3
try this O2 sensor plug if it already has a bun
http://www.summitracing.com/parts/SUM-G2990SS-1/
if you do not have a bun then you need to weld one on like this one:
http://www.summitracing.com/parts/AAF-ALL34153/
You can probably get these at a local parts store.
Old Dec 1, 2011 | 01:45 PM
bugzbunny's Avatar
bugzbunny
oh thank you also the plug in header has no threads so now what?
Old Dec 1, 2011 | 02:32 PM
blckslvr79's Avatar
blckslvr79
Are you saying it's just a hole drilled in the tube or is there a bung welded in the pipe????? Got pictures?
Contact Josh.
He can tell you exactly what you need.
Old Dec 1, 2011 | 02:34 PM
bugzbunny's Avatar
bugzbunny
their is a bung welded into the pipe but it has no threads
Old Dec 1, 2011 | 03:27 PM
blckslvr79's Avatar
blckslvr79
That's odd. Maybe they left it that way so the buyer can tap the threads they need??? In that case, you need a plug and a matching tap/die kit.
Or a welder and some scrap steel.
Old Dec 1, 2011 | 05:35 PM
Johns vette's Avatar
Johns vette
I have the same pipes from Josh. There were threads on the inside of the hole. They should be there.
John
Old Dec 4, 2011 | 10:11 AM
bugzbunny's Avatar
bugzbunny
yea I finally woke up and saw the threads, had to drive to several stores to find the plug, thanks guy's (;
To Headers and side pipes
