1969 Frames
Old Dec 1, 2011 | 01:11 PM
Al 1963's Avatar
Al 1963
4th Gear
Default 1969 Frames
I am looking at a 69' conv. with a 2 holes in the frame as described in the ad for it. What kind of money does it take to replace a frame on these cars if needed? Does the "birdcage" rust badly as well? Thanks
Old Dec 1, 2011 | 01:46 PM
Mike Ward's Avatar
Mike Ward
If the frame AND birdcage need replacement, you're looking at maybe $15K for parts and labour. Very few cars are worth it.
Old Dec 1, 2011 | 01:55 PM
Al 1963's Avatar
Al 1963
4th Gear
Thanks for the quick response. The car is a complete un-molested example, matching numbers, still had all the equipment under the hood, smog pump, protecto plate, and build sheet. It's also all original paint, 350-300hp, 4 speed, with new interior. It's kind of a survivor, but, I'll wait til the photos show up to see if its worth the 4 hour ride.
Old Dec 1, 2011 | 05:52 PM
Alan 71's Avatar
Alan 71
Hi Al,
The car sounds like the 69 might be a very interesting find.
Check very carefully for RUST because IT'S 'molestation' is the WORST kind.
Hopefully it's not too bad!
Regards,
Alan
Old Dec 1, 2011 | 06:18 PM
Al 1963's Avatar
Al 1963
4th Gear
Just got more info on the 69'. The birdcage looks descent but the windshield frame needs replacement...It's starting to look more like a parts car : (
Old Dec 1, 2011 | 08:38 PM
joewill's Avatar
joewill
if the frame has holes in it, and the windshield frame is shot, I would have a hard time believing even an expert telling me that the birdcage is fine...
on an unmolested car, it is never 2 out of 3.. it is all 3,
subtract 75% from the asking price, or walk away...
to answer your question.. you can get a used frame maybe for 2500 if you shop around and go fetch it yourself. new ones are 4000+ several hundred to ship.. but on rusted frames, the repair will escalate... parts will break, bolts will strip, and the 'while it is apart' disease will take over.. are you really going to just slip a new frame under a car with old u-joints, old suspension bushings, shocks, transmission mounts, old brake and fuel lines?
unless you really know what you are doing and want to devote about 3 years of your life to the car.. run forrest run...
Old Dec 1, 2011 | 09:06 PM
Mike Ward's Avatar
Mike Ward
The windshield frame is THE most critical part of the birdcage. Run Forrest!
Old Dec 2, 2011 | 07:25 AM
Al 1963's Avatar
Al 1963
4th Gear
Thanks to all for info and advice. I am a car guy but dont know much about Corvette's. I guess I'm walking away from this one. Happy Holidays to all!
Old Dec 2, 2011 | 08:18 AM
redvetracr's Avatar
redvetracr
is the car a gold coupe by any chance?
Old Dec 2, 2011 | 09:40 AM
cm2dinger's Avatar
cm2dinger
@redvetracr
He said it was a convertable.
Old Aug 19, 2019 | 10:15 PM
standardbyke22's Avatar
standardbyke22
what compounds do you use after wet sanding, and what kind of pads, form or wool? i was using foam and i think its making scratches in the paint, in the sun i see a bunch of round scratches and the polishing compound isnt taking them out
Old Aug 19, 2019 | 11:09 PM
davidchristopher's Avatar
davidchristopher
This thread is eight years old. Furthermore, your question is off topic.
Create a new thread dude.
Old Aug 19, 2019 | 11:21 PM
standardbyke22
thanks dude, i see what happened a related thread popped up and i posted to this thread instead of the one i wanted to, opps
thanks again for the heads up dude
Old Aug 19, 2019 | 11:22 PM
davidchristopher
I hate that feature. lol.
Old Aug 20, 2019 | 08:59 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You can turn it off.
To 1969 Frames
