electric fan temp sensor problem
Old Dec 4, 2011 | 09:33 AM
Tim H's Avatar
Tim H
Default electric fan temp sensor problem
Hey, I changed over to a electric fan set up and a 175/185 temp sensor and it worked real well for awhile then I noticed yesterday that the temp was not ever coming up to proper temp.
I used my temp gun at the sensor and it said 86 degrees and the fans were on?
I guess that means the sensor is bad already?
Old Dec 4, 2011 | 07:03 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Could be the sensor or perhaps the fan relays assuming you're not using a pwm fan controller. When the fans are on, unplug the temp sensor. If the fans quit, it's the sensor. If not, it's probably the relays.
Old Dec 4, 2011 | 07:17 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Hey Tim, off the subject a little...I am getting ready to run the electrical for my dual fan setup. How did you run your wiring in regards to the main power source? Did you run it all the way to the battery or did you find another place? Also, where did you mount your sensor(assuming it is a block mount style)?
Old Dec 4, 2011 | 07:40 PM
terry82's Avatar
terry82
can you run the hot wire to the fan , off the wire to the starter?
Old Dec 4, 2011 | 07:50 PM
Tim H's Avatar
Tim H
I get my power from the Alternator, and since my car is a hotrod I put the relays and stuff right where they can be seen and maintained if they need to be.
[IMG][/IMG]
Old Dec 5, 2011 | 02:56 PM
Tim H's Avatar
Tim H
Jegs is sending me another sensor for free.
Its hard to pick where to get parts with Summit and Jegs always being hassle free!
Old Dec 5, 2011 | 03:59 PM
Bruthish's Avatar
Bruthish
I have never had a problem with Summit and depending on what time of day I order, I usually get my parts the next day.
Did you mount your sensor/switch into the manifold?
Old Dec 5, 2011 | 04:06 PM
Tim H's Avatar
Tim H
Yes on the drivers side of the thermostat housing.
To electric fan temp sensor problem
