Add RH rear mirror
Old Dec 6, 2011 | 05:20 AM
Iron_dog's Avatar
Iron_dog
Default Add RH rear mirror
Is this hard to do? any suggestions in order to do the job?
Old Dec 6, 2011 | 07:19 AM
palmbeachvette76's Avatar
palmbeachvette76
Not hard at all. It comes with a paper template to drill the necessary holes for the threaded inserts. If I were you I would drill a small hole and use stainless screws instead of drilling the larger hole for the rubber inserts that come in the kit since the rubber tends to move around a bit and the mirror wiggles some, nothing major but it's noticeable.
Probably takes a total of 15 minutes to complete the install if that.
Old Dec 6, 2011 | 07:21 AM
Iron_dog's Avatar
Iron_dog
Thanks! Do I have to open the interior of the door? (stupid question maybe... sorry)
Old Dec 6, 2011 | 07:50 AM
palmbeachvette76
no you don't, everything is done outside of the car. The paper template fits the upper part of the door from the fender opening to the window so it's a piece of cake to set it in place with some blue painters tape to hold it then drill. There is a metal plate an inch or so behind the exterior door panel so you don't have to worry about hitting the door glass either when drilling.
Old Dec 6, 2011 | 08:11 AM
Iron_dog's Avatar
Iron_dog
Great!! Thank you!
Old Dec 6, 2011 | 11:35 AM
7T1vette's Avatar
7T1vette
Start with a smaller drill size and work your way up to the final drill size. That will minimize risk of paint and/or fiberglass cracking.
To Add RH rear mirror
