connecting battery tender?
Old Dec 7, 2011 | 11:31 AM
optiman's Avatar
optiman
Default connecting battery tender?
Ok I give up. First time connecting battery tender. can't figure out how to remove batery cables. 1979 corvette. do I remove battery from car? I've done that but unscrewed terminals from battery to do it. do cables just peel off terminals. last resort to look like an idiot on the forum.
Old Dec 7, 2011 | 11:44 AM
MelWff's Avatar
MelWff
why are you trying to remove the battery? You take the alligator clips on tender and clamp them to the appropriate terminal, + to +, - to -.
Old Dec 7, 2011 | 01:07 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Connect the tender's cables to their respective positive/negative battery position BEFORE plugging the tender into an electrical outlet. There's no need to remove the battery from the car.
Old Dec 7, 2011 | 03:21 PM
tekvette's Avatar
tekvette
Lol. u need to remove the cables before hooking up the tender to be safe.
If u cannt figure out how to take off cables, u probably shouldn't be doing this without help. Do u have a neighbor that can help u? Friend maybe?
Old Dec 7, 2011 | 03:56 PM
SH-60B's Avatar
SH-60B
You have a side terminal battery, and you don't have to disconnect it for a battery tender
Old Dec 7, 2011 | 04:10 PM
MelWff's Avatar
MelWff
apparently the OP is ignoring all of us!
Old Dec 7, 2011 | 05:53 PM
optiman's Avatar
optiman
First who is OP?
I just connect clamps to battery and plug into wall, then just walk away.
or should i just plug in once a month for a day? neg "-" first then pos "+".
sorry to be a pain, someone has to ask the dumb questions.
Old Dec 7, 2011 | 05:57 PM
kjb13's Avatar
kjb13
You are the OP (original poster). Just hook it up and leave it on.
Old Dec 7, 2011 | 06:01 PM
optiman's Avatar
optiman
thanks
Old Dec 7, 2011 | 06:05 PM
optiman's Avatar
optiman
when would you use the cigarette lighter attachment?
Old Dec 7, 2011 | 06:34 PM
flyeri's Avatar
flyeri
Use cig adapter and you don't have to clamp to battery terminals. Just plug in to cig receptical, plug into house receptical and go away.
You can leave it plugged in all winter.
Old Dec 7, 2011 | 07:20 PM
optiman's Avatar
optiman
the cigarette lighter doesn't work, do you think the charge will still get thru?
Old Dec 7, 2011 | 08:23 PM
flyeri's Avatar
flyeri
Is there no power to the recepticle or is the heating element burned out? You really need to identify that problem to be able to answer your question. I think I would just put the clips on the battery if I were you.
Old Dec 8, 2011 | 09:20 AM
69 Chevy's Avatar
69 Chevy
The proper procedure is to attach the (+) positive alligator clip first. Then attach the (-) negative or ground clip but not to the battery, to another metal ground bolt some distance away from the battery. Doing this lessens the chances of a spark igniting the hydrogen gas given off by a charging storage battery. Reverse this procedure when disconnecting the charger...negative (black) first, then positive (red).
Old Dec 9, 2011 | 01:58 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Is it that hard to connect a (+) and (-) terminals to a car battery?
Old Dec 9, 2011 | 06:32 AM
optiman's Avatar
optiman
what ground bolt would you find inside the car?
Old Dec 9, 2011 | 07:31 AM
Jud Chapin's Avatar
Jud Chapin
If I were you, and as suggested above, I would have a friend who is competent in such an area, show you how to do the hook up. If when doing the hook up a spark is generated, it can cause an explosion of the battery and obviously do physical harm to you and the car.
http://www.vinland.com/car-battery.html
To connecting battery tender?
Old Dec 9, 2011 | 07:41 AM
69 Chevy's Avatar
69 Chevy
For me it's the convertible top mounting bolts.
Old Dec 9, 2011 | 09:50 AM
redvetracr's Avatar
redvetracr
question how many CF members does it take to hook up a battery tender?
answer: I don`t know but I bet the OP is sure having fun.
Old Dec 9, 2011 | 11:03 AM
MelWff's Avatar
MelWff
Not to mention most battery tenders come with detailed instructions!
