Engine Backfire
Old Dec 8, 2011 | 12:13 PM
8T_BlackBeauty's Avatar
8T_BlackBeauty
Default Engine Backfire
I have a 1980 with a crate engine from 2009. Recently bought the car so I'm just starting to tare into it and start getting it running well. For the most part the engine runs pretty well, but I've been noticing a backfire. It usually backfires when I first start the car and rev it to get it warmed up. I also hear it when I let off the gas to shift from first to second. I don't normally hear a backfire going to any other gears. I will also sometimes get a little bit slowing down at lights when in first.
I have 92 octane in it (I haven't been able to find 94 anywhere in town yet). I also have the gas cap lose to ensure it's venting. I'm not sure what's going on or if I have anything to really be concerned about. The backfire isn't super loud it's more like a slight pop. Any help would be appreciated!
Old Dec 8, 2011 | 12:19 PM
MelWff's Avatar
MelWff
what is your total and initial timing set for?
Old Dec 8, 2011 | 02:27 PM
scottw's Avatar
scottw
May want to set your timing according to this paper from Lars and see how it is running afterwards.
How to Set the Timing
When you think about it, setting the timing at idle speed makes no sense at all: You don’t operate your car at idle, and timing changes as the rpm changes. Fact is, the timing spec at idle speed is provided as a simple way for most people to set the timing, and is not a good procedure for optimum performance.
Small block Chevys (and most other GM performance V8 engines) perform best when the total timing (full centrifugal advance plus the initial timing setting with vacuum advance disconnected) is all in by 2,500 – 2,800 rpm and is set to 36 – 38 degrees. If you have an adjustable timing light, this is very easy to check. If you don’t, you need to scribe a 36-degree mark on your harmonic balancer. Here’s how:
Measure the circumference of your harmonic balancer using a sewing tape measure (or other flexible tape measure). Get it as accurate as you can. Take this measurement and divide by 10. The number you get is the distance to 36 degrees. Measure this distance CLOCKWISE from your existing harmonic balancer timing mark and place a clear mark on the balancer.
Remove your distributor cap and rotor. Remove the 2 centrifugal advance springs. Install the rotor and the cap (without the springs). Disconnect the vacuum advance.
NOTE: This procedure cannot be used on the HEI ignition systems. Removal of the springs will cause an artificially over-advanced condition that will never be achieved with the springs in place. You can use the basic technique described in this paper with the HEI units (setting timing up to 36 degrees), but to check total timing, you must install a set of soft springs. You cannot remove the springs altogether. With the soft springs in place, rev the engine until the centrifugal advance is pegged out. Adjust for 36 degrees total. Then re-install your original springs.
Start the engine. It may kick back a little due to the advance coming in immediately without the springs. If you’re using an adjustable timing light, set the light to 36 degrees advanced. Now rev the engine just a little while observing the timing marks with the light. It shouldn’t take much rpm to peg out the advance without the springs installed. With an adjustable light set at 36 degrees, align the stock timing marks with “0” when the timing is “pegged out.” With the non-adjustable light, align your new 36-degree mark with “0.” Rev the engine a little to make sure the timing will not advance any further. Shut it down.
Pop the cap and rotor and re-install the springs. Put everything back together, but leave the vacuum disconnected. Start it up. For future reference, make a note of the timing setting at idle. This is your new curb idle timing spec. Now give the engine a few quick rev’s past 3,000 rpm and verify that the full timing (36 degrees) is coming in. If it’s not, you need to change to a softer set of springs until you get full 36-degree advance before 3000 rpm. (NOTE: A stock set of springs will usually not allow full centrifugal advance to come in before redline rpm. If you have stock springs installed, don’t rev the engine beyond its limits to try to force full advance in.)
Shut it down and hook up the vacuum. Now do a road test.
The 36-degree 2500 rpm advance curve is optimum for performance, but may require premium fuel. Lug the car around, and punch the throttle at low rpm while listening for detonation (“engine knock”). If you’re getting any audible knock, you MUST retard the timing. Retard the timing in 2-degree increments until engine knock stops. Engine knock will seriously damage engine components if not corrected. If you get no knock, you may see slightly improved performance at 38 degrees total timing. This is particularly true if you’re running at high altitude.
If you have no engine knock under acceleration, but the car “chugs” or “jerks” at cruising speed (light throttle application), you are getting too much vacuum advance on top of the mechanical advance. You may need to change out the vacuum advance diaphragm with an adjustable unit available from aftermarket sources. Adjust these units so that you get the most vacuum advance possible without any “chugging” or “jerking” at cruise speed.
Your timing is now set for best possible performance. Make note of the new setting, and use this for your future tune-up work.
Old Dec 8, 2011 | 03:02 PM
8T_BlackBeauty
Mel not sure what my timing is set at. But that seems to be the consensus about what's up so I'll try that.
Is it something to be worried about? Should I not drive it until the issue is resolved?
Old Dec 8, 2011 | 03:29 PM
MelWff's Avatar
MelWff
I would try to resolve it as soon as possible, incorrectly set timing can result in more expensive repairs.
Old Dec 8, 2011 | 05:58 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
"I also hear it when I let off the gas to shift from first to second. I don't normally hear a backfire going to any other gears. I will also sometimes get a little bit slowing down at lights when in first."
Classic vacuum leak symptoms. You're backfiring during periods of peak vacuum signals.
Old Dec 8, 2011 | 11:14 PM
8T_BlackBeauty
Dark blue that makes sense. I'm pretty sure I have a leak since my headlights won't come up on their own. What about the leak contributes to the backfire?
Old Dec 8, 2011 | 11:52 PM
73, Dark Blue 454
A vacuum leak is air getting to the combustion chamber without going through the top of the carb. Since this air isn't metered by the carb, your engine suffers a lean condition which can cause backfiring through the exhaust.
This lean condition is most pronounced during high vacuum conditions such as deceleration. If lean, she can also surge a bit during cruise.
To find the leak, start at the carb's base and intake-to-head sealing. Squirt carb cleaner in the possible problem areas and listen for changes in the engine's idle speed. An incorrect carb gasket can open up a leak, especially using on earlier q-jet on a later intake manifold.
Then chase each vacuum hose (there are many) from the carb (and/or intake manifold) to it's destination. Look for cracks, etc. With a tuned ear, you may can hear the leak.
If you don't discover a vacuum leak, your carb could simply be way too lean.
Check for the vacuum leak first then report back.
Good luck!
Old Dec 12, 2011 | 08:15 PM
8T_BlackBeauty
Dark Blue. I'll give that a shot. It makes sense that the carb may have a leak the other bubba has at least 5 gaskets and a spacer at the base. I'll see what getting rid of those will do. Unfortunately it'll have to wait until I get back from the sandbox...
Old Dec 12, 2011 | 08:50 PM
jimboscarbs's Avatar
jimboscarbs
Default gets my vote
Good luck!
This one gets my vote
To Engine Backfire
