Voltmeter on 77?
Old Dec 9, 2011 | 12:17 PM
Acesone's Avatar
Acesone
Default Voltmeter on 77?
Red light comes on when started and then goes almost out. Gauge shows abt 8-9 volts but does not kill the battery. Took off neg.on bat and it died .New alt. and then it did not stop. Rich
Old Dec 9, 2011 | 02:10 PM
MelWff's Avatar
MelWff
Did you put a voltmeter on the output post of the alternator? Did you check the 2 wire connector to make sure it's fully seated and not corroded?
Old Dec 9, 2011 | 04:01 PM
wnmech's Avatar
wnmech
Sounds like the diode trio inside the alternator. Take the alternator to be tested and the test equipment will confirm what failed. They sell overhaul kits pretty cheap and they are easy to overhaul
Old Dec 9, 2011 | 06:54 PM
Acesone's Avatar
Acesone
Default 77 Alt.
Tnx guys and Mel you hit it right. thanks both for the help!! Rich
To Voltmeter on 77?
