I think they will fit?
Old Dec 10, 2011 | 01:20 PM
Aldo_45030's Avatar
Aldo_45030
Default I think they will fit?
Lookign at purchasing a set of used American Racing Torq II polished 15 X 8 X 4 3/4 BC 4 1/2 back space Chevy with P265/50 R15 to put on my 82. From what i have read the tire will fit but i question the backspacing would be correct plase advise.
Old Dec 10, 2011 | 01:31 PM
gcusmano74's Avatar
gcusmano74
The factory 8" wide wheels have a 4" backspacing- the offset is zero. If you use a wheel with a longer backspacing, that will pull the wheel further into the wheel well of the car, closer to the trailing arm.
Old Dec 10, 2011 | 06:35 PM
Aldo_45030's Avatar
Aldo_45030
Doesnt sounds as if there is room the tires are .43" wider than 255/60-15 .
Old Dec 10, 2011 | 08:16 PM
C3 Shark's Avatar
C3 Shark
3rd Gear
You will need a 1/2 spacer to clear. I am currently running a similar combination. I am going to go to a 17x8 and 17x9 combination with zero offsets.
To I think they will fit?
