Power Steering Valve
Old Dec 10, 2011 | 01:43 PM
wajulia's Avatar
wajulia
Default Power Steering Valve
Went to pull the power steering valve and piston to rebuild them to stop a long standing leaking issue. Thing is, I cant get the Valve off the car. I can not get the stud to pitman arm to release. Beating the snot out of it with a pickle fork -- am I missing something or should I keep beating it?
Old Dec 10, 2011 | 01:47 PM
71scgc's Avatar
71scgc
Get a puller. Put it on, wrench it down real tight, and hit the pitman arm by the stud on the valve. Retighten the puller as needed...
Old Dec 10, 2011 | 02:01 PM
Steve2147's Avatar
Steve2147
I never use a pickle fork any for releasing tapered studs. They ruin the seals (if you had planned to reuse them) and mark the studs up.
Hold a bf hammer against one side of the pitman arm adjacent to the stud and whack the other side with another bfh. The stud will pop out after a few good whacks. On the pitman, if you have a pitman puller it is sometimes easier to remove the pitman from the steering box then remove the pitman from the valve stud. That way you can lay the pitman against some kind of anvil while you whack the other side instead of holding a hammer against it.
Steve g
Old Dec 10, 2011 | 02:20 PM
wajulia's Avatar
wajulia
Thanks for the help-- continued beating eventually prevailed. Hope I didnt damage the valve.
Old Dec 10, 2011 | 02:42 PM
Jim Shea's Avatar
Jim Shea
The trick is the bf hammer resting against the pitman arm when you hit it on the other side with another bf hammer. The stationary hammer absorbs most of the energy and prevents it from being transfered up into the steering gear.
Jim
To Power Steering Valve
