Swaybar & shock install question
Old Dec 10, 2011 | 02:18 PM
bruisedknuckles's Avatar
bruisedknuckles
Default Swaybar & shock install question
Replacing front sway bars today along with front/rear shocks. Usually use the frame (right under door hinges) as jack points. Do I need any additional support under the control arms for the front?
My first time doing this, so suggestions would be welcome.
-D
Old Dec 10, 2011 | 03:06 PM
scottw's Avatar
scottw
You should be good with jackstands under the frame.
Maybe a jack under the control arm but you're not removing the spring so probably don't really need it. I did my shocks four years ago when I rebuild the front suspension so I had everything taken off when I did mine.
