Big Block Pulleys
Old Dec 12, 2011 | 03:52 PM
richiev88's Avatar
richiev88
Default Big Block Pulleys
Hi,
Can anyone whom may have been down this road give me the heads up whom is the best vendor to purchase a set of Big Block pulleys to suit factory brackets??
I have searched and scraped around here ( New Zealand), tried various after maket pulleys but nothing seems to work right.
So i'm about to bite the bullet and buy a repo set.
Cheers Richie
Old Dec 12, 2011 | 05:37 PM
Ironcross's Avatar
Ironcross
early 396 Camaros [67-68] use the same water pump and alternator mounted on the left side therefore you could use those pulleys and there cast iron alternator bracket too....the car below also has PS and AC
Old Dec 12, 2011 | 06:28 PM
midyearvette's Avatar
midyearvette
Originally Posted by richiev88
Hi,
Cheers Richie
ecklers has them and they ain't cheap!!
Old Dec 12, 2011 | 09:14 PM
ajrothm's Avatar
ajrothm
I bought all of the factory reproduction big block pulleys and brackets from Corvette Central. The pulleys were really good quality....the repro brackets on the other hand sucked.... I am still fighting with the PS pump bracket trying to bend/tweak it to help with belt alignments on the PS pump pulley...
I spent some serious jack on those pulleys and brackets.... Water pump pulley alone was like $200 for a 3 groove....
I think I spent about a grand on all of the pulleys and brackets...
Old Dec 12, 2011 | 09:16 PM
ajrothm's Avatar
ajrothm
Those camaro brackets are not even close to the same as the vette brackets.....They may still work but....they arent the same. That alternator sits way too high for a Vette....hood wont clear it.
Old Dec 12, 2011 | 10:05 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I ordered all my Corvette BB. brackets and pulleys,
from Bairs Corvettes / Bairs.com
Great service too. !
Old Dec 12, 2011 | 11:09 PM
Ironcross's Avatar
Ironcross
Default You dont know your BB`s
I went through this a few months ago when it was said the alt is too high...sorry but its the 'same bracket as shown in the Corvette Central book and on both of my cars in question plus 3 more
unless I have the only Vette that uses a Camaro alt bracket and I know that's not correct...as I own them both and from new..
Old Dec 12, 2011 | 11:57 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The brackets are very similar but not the same.
Camaro bracket
Corvette bracket
If you look close you will notice the corvette bracket mounts the alternator lower.
I actually tried the non-vette bracket on my car, and the top of the alternator hit the hood.
Old Dec 13, 2011 | 09:48 AM
Big Block 69's Avatar
Big Block 69
I used the early Camaro pulleys, brackets and water pump on mine.Everything fits fine, and there is plenty of room to close the hood.
To Big Block Pulleys
