Got a rocker problem..
Old Dec 14, 2011 | 05:40 PM
fanmanbd's Avatar
fanmanbd
He's thinking that the top of the valve is not flat anymore and will **** the rocker to one side again
Old Dec 14, 2011 | 05:47 PM
Birdman's Avatar
Birdman
Well I put the new one one and noticed it is a little wider, which is probably helpful..
I noticed while looking at some of the others, that many of them are not centered, but resting on the edge of the valves..why is that? Is it because they lack some sort of guide? Should I buy some? I've seen them on summit before..or would the local parts store have them?
Here's some pics:
Birdman's Avatar
Birdman
It appeared flat before I put the new one on.
Old Dec 14, 2011 | 05:53 PM
fanmanbd's Avatar
fanmanbd
I would adjust the lifter and then close it up and see what happens. I think it will be fine.
Good luck.
Old Dec 14, 2011 | 06:04 PM
Birdman's Avatar
Birdman
Good luck.
...how do you do that?
Old Dec 14, 2011 | 06:16 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
It's the tip of the valve stem that wore through the lifter. As long as that tip has not worn away to the point that the wedges that hold the valve spring retainer in place fall out, you should be fine. That is something that I have never seen happen before. It is a good idea to see that the valves are all opening to verify no cam damage. If there is severe wear, the valve at that location will not move as much (or at all).
Old Dec 14, 2011 | 06:24 PM
fanmanbd's Avatar
fanmanbd
The easiest but sloppy way is to warm up the engine with the valve cover on and then remove the cover start the engine and loosen the rocker until it taps and then tighten until it stops tapping and then tighten 3/4 turn more. The clean way is warm the engine then bring the piston all the way up on that cylinder and tighten the rocker until it just touches the stem and then tighten another 3/4 turn.
Old Dec 14, 2011 | 07:12 PM
Birdman's Avatar
Birdman
Well that did it! No more ticking, or any unwanted noises. That was the problem and I'm so relieved that it wasn't something more serious. Due to no abnormal wear on the valvespring, stem, or rod, my guess is that it was just old and worn out, and possible bad timing in the past could have made it worse.
Thanks everyone for your help!
Old Dec 14, 2011 | 07:27 PM
sly vette's Avatar
sly vette
So is it everyones opinion that there is no damage to the bearings with the small particles of metal floating around.
Old Dec 14, 2011 | 07:35 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Its unlikely that there is a ton of metal floating around.
The typical way for a stamped rocker to fail is to snap all at once, not to grind away slowly.
Normally they fail on the pushrod side though.
Old Dec 14, 2011 | 07:51 PM
Birdman's Avatar
Birdman
I'm all ears..tell me what to do guys.
Old Dec 14, 2011 | 08:49 PM
noonie's Avatar
noonie
Double check the pushrod guides in the head. When that happens over time, I have seen the slot wear badly and the new rocker won't stay straight for very long.
Old Dec 15, 2011 | 10:37 AM
  #33
Birdman's Avatar
Birdman
Do the guideplates go on top of the heads or somewhere else? I don't see any on top.. should I get flat or raised?
Old Dec 15, 2011 | 11:52 AM
  #34
69 Chevy's Avatar
69 Chevy
Guideplates are fastened under the screw in rocker studs. You're opening up a whole can of worms installing them...guide plates require special hardened push rods. Don't bother.
In the 'for-what-it's-worth' department, and I say that because not many still fool with the OEM stamped rocker arms, but the best GM small block rockers has a raised triangle on the valve end. I don't see them in birdman's pics.
You can see it in this pic:
Old Dec 15, 2011 | 08:35 PM
  #35
mirage2991's Avatar
mirage2991
you should really pull the pushrod out on that one and check for straightness. If you have granite counters, that works great, just roll it on it and look to see if it's wiggling up and down. A glass top will also work.
Over tightening won't do that to a rocker: on a hydraulic cam, you would just push the lifter plunger down, eventually making it a solid lifter cam, but you'd have other issues and you would know it imediatly (poor perf, backfiring, caughing out the carb etc). On a solid cam, you would have the valve hanging open, and you'd know it too...
It could be a sign of valve float, but, it would show on the other rockers...can't really know for sure unless you have a spring pressure checker and know what the spring pressure is for those to begin with...I happen to have that tool...along many others...
Do yourself a favor (and me lol) take a magnet and pass it over the head where the oil is returning to catch any pieces...do an oil change with new filter...and while you are in there, can you get me the heads number?
Old Dec 15, 2011 | 08:50 PM
  #36
Birdman's Avatar
Birdman
I already did that, and it was straight. After I fixed that rocker, I've had no problems..no sounds, nothing.
Where's the heads number?
I'll definitely do an oil change for you. I was able to pick a big chunk of the rocker off the top of the heads, which appeared to be 95% of the metal.
Old Dec 15, 2011 | 08:56 PM
  #37
mirage2991's Avatar
mirage2991
good man!!
I was talking about head casting number...should be in there somewhere...been a while since I looked at an SBC block (I'm a BBC guy)...check between the rockers of cyl 2 and 4, I think I can see something there on your pic...
To Got a rocker problem..
Old Dec 15, 2011 | 08:59 PM
  #38
Birdman's Avatar
Birdman
Alright...I guess I'll pull the valve cover off one more time...lol
Old Dec 15, 2011 | 09:04 PM
  #39
mirage2991's Avatar
mirage2991
lol well you don't really have to, when I posted I thought you still had it open...
Old Dec 15, 2011 | 09:12 PM
  #40
Birdman's Avatar
Birdman
Hell no! I fixed that thing as soon I as I could and got it back on the road, especially with these fine weather days! Plus I had a couple more people in the area who wanted to look at it.
