Got a rocker problem..
Old Dec 14, 2011 | 03:19 PM
Birdman's Avatar
Birdman
Default Got a rocker problem..
When I started up the car today, I heard a loud ticking noise..not a knock, but ticking. So I first checked the header bolts, and sure enough, they needed some tightening. Turned the car on, still ticking. Then I replaced the gasket which was worn out and needed replacing. Still ticking. Then I saw that where the side pipe and header meet, needed tightening..still ticking.
Then I took the valve cover off on the passenger side and found this gem:
What would cause this? Over-tightened rocker?
And what are the implications? Was that the source of the tapping? Can I simply buy a new rocker (set)?
Help me out guys..I'm trying to sell this car and want to get it back up and running quickly. Thanks for the help.
Old Dec 14, 2011 | 03:26 PM
fanmanbd's Avatar
fanmanbd
Is the valve spring broken?
Old Dec 14, 2011 | 03:36 PM
MelWff's Avatar
MelWff
Without knowing the full history of the engine difficult to come up with the exact answer. if original from 1968 just worn out. I would check the rocker arm stud to see if there is a groove worn on the side of it from the rocker being cocked at that angle. Depending on how far you want to go, at the very least replace the rocker arms and any worn rocker arm studs. Ideally you should have the heads converted to screw in rocker studs with pushrod guides. Obviously change the oil and filter no matter what you do.
Old Dec 14, 2011 | 03:38 PM
Birdman's Avatar
Birdman
Doesn't appear so. I looked at it all around, as well as pressed down on it a little. Doesn't seem like anything else is messed up..
Would this work as a replacement?
http://www.summitracing.com/parts/CCA-1212-1/?rtype=10
:EDIT:
I see that the above stud size is not 5/8...
Birdman's Avatar
Birdman
Rocker arm stud appears fine as well.
Old Dec 14, 2011 | 03:45 PM
MelWff's Avatar
MelWff
these would be better
http://www.summitracing.com/parts/CCA-1412-16/
Old Dec 14, 2011 | 03:46 PM
Birdman's Avatar
Birdman
Will the link I posted work?
And keep in mind I don't have money anymore..and so I'm not looking to convert anything, or even improve. Simply get working again.
And do you think that tapping was from the rocker, or the pieces from the rocker?
Old Dec 14, 2011 | 03:49 PM
MelWff's Avatar
MelWff
It was from the rocker but you need to replace all of them. This would be a better choice
This is the cheaper choice
http://www.summitracing.com/parts/CCA-1212-16/
Old Dec 14, 2011 | 03:52 PM
bigvette1's Avatar
bigvette1
Understand you dilemma on this $$ issue. If not replacing all rockers, yes the bare bones Summit with ball and nut will work. As an alternative to save some $$ ck out some of the local machine shops that build engines and I bet they have some old 1.6 rockers, ***** and nuts laying around that they might just give you one.
Old Dec 14, 2011 | 03:53 PM
Birdman's Avatar
Birdman
Just to confirm:
-I'm supposed to get roller tips, instead of non-roller like what's in there now?
-Rocker arm ratio is 1.52?
-Stud size is 3/8"? Am I thinking of the same thing? The nut that I took off of the rocker was 5/8..
-Long slot style instead of standard?
Old Dec 14, 2011 | 03:56 PM
MelWff's Avatar
MelWff
-Rocker arm ratio is 1.52? Correct slight performance increase
-Stud size is 3/8"? Am I thinking of the same thing? The nut that I took off of the rocker was 5/8.. The stud is 3/8 in diameter not the nut.
-Long slot style instead of standard? The part number I posted had only one type of slot
Old Dec 14, 2011 | 04:05 PM
Birdman's Avatar
Birdman
Awesome, I appreciate all of the help, and thanks for bearing with me, I'm still learning.
Will these work fine? And which means more performance as you stated, 1.5 or say 1.6?
http://www.summitracing.com/parts/MAN-43140/?rtype=10
Old Dec 14, 2011 | 04:09 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Your local auto parts store can get you replacement rockers for about $3 each.
There really isnt a reason to replace the whole set unless you just feel like it.
Old Dec 14, 2011 | 04:14 PM
fanmanbd's Avatar
fanmanbd
Old Dec 14, 2011 | 04:30 PM
jordan89's Avatar
jordan89
Old Dec 14, 2011 | 04:31 PM
STL 71 C3's Avatar
STL 71 C3
there is no way that valve stem doesn't have damage.
If you replace just the rocker you will be doing it again very soon with the valve and possibly other parts as well.
The rocker would have had to be in a bind to do that. Does the head have guide plates? Are they worn?
Old Dec 14, 2011 | 04:42 PM
GOSFAST's Avatar
GOSFAST
Default Valve/rocker damage
Just a "heads-up", the rocker in the photo to the left of the broken one appears to also have an issue!
Tough to tell from the photo, but something doesn't look right?
Thanks, Gary in N.Y.
P.S. I would recommend checking for possible "flat" cam lobes AND incorrect (late) ignition timing!
To Got a rocker problem..
Old Dec 14, 2011 | 05:06 PM
dochorsepower's Avatar
dochorsepower
GOSFAST Gary got me to thinking and I looked at the pictures again. What about that left rocker? Has the nut been loosened? Check for bent pushrods.
Good luck, Bill
Old Dec 14, 2011 | 05:26 PM
Birdman's Avatar
Birdman
Just got back from the parts store, bought two for $4.
And Gary, now you've got me worried.. is it because it appears misaligned? How do you correct that?
How do I check for flat cam lobes? I know of them and the issue, and have been using recommended oil.. And the timing has been done by me multiple times, so I'm fairly certain it is correct..
Old Dec 14, 2011 | 05:30 PM
Birdman's Avatar
Birdman
Could you elaborate on the valve stem?
I don't believe the heads have guide plates..what do they look like?
And to address someone else's question, the pushrods appear fine and straight..
