which holley carb will fit?
Old Dec 16, 2011 | 11:31 AM
smyth1's Avatar
smyth1
Default which holley carb will fit?
built a basically original 350 horse small block.i used the lt 1 intake.what size holley should i use that will clear the hood with the original air cleaner.thanks
Old Dec 16, 2011 | 03:02 PM
Alan 71's Avatar
Alan 71
Hi s,
I guess it depends on what year your car, hood, and air-cleaner are.
The original LT-! intake with it's Holley and open air-cleaner required the clearance given by the bb hood.
I looked at your profile for a clue.... but it's blank.
Regards,
Alan
Old Dec 16, 2011 | 03:15 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just an item to consider. Many stock air cleaner bases have interference issues with double pumper Holleys. Doublecheck that area before you spend any money.
Old Dec 16, 2011 | 04:06 PM
scottyp99's Avatar
scottyp99
I think they are all pretty much the same thickness, if that's what you're getting at.
Scott
Old Dec 16, 2011 | 04:20 PM
smyth1's Avatar
smyth1
it is a 69 small block car.i have the stock hood and air cleaner.
Old Dec 16, 2011 | 05:51 PM
Alan 71's Avatar
Alan 71
Hi S,
It's my understanding that with the LT-! intake the front of the air-cleaner contacts the sb hood. That's why the bb hood has the additional height towards the front of the hood compared to the sb hood.
Regards,
Alan
Old Dec 16, 2011 | 06:56 PM
Phil Zell's Avatar
Phil Zell
here is my old 68 with a LT1 intake and stock hood, all you need is a drop base air cleaner.
Old Dec 17, 2011 | 08:34 AM
Alan 71's Avatar
Alan 71
Hi Phil,
Is the crankcase breather hooked up? Do you remember what brand of air cleaner you used?
Regards,
Alan
Old Dec 17, 2011 | 07:44 PM
Phil Zell's Avatar
Phil Zell
Originally Posted by Alan 71
Hi Phil,
Regards,
Alan
Alan I sold this car about 6 years ago and only remember I bought the drop base air cleaner from Noah Performance on Ebay, yes the vent hose was active.
The intake was the 116 service replacement for the 1970 LT-1
The carb was a 750 vac secondary Holley
To which holley carb will fit?
