Vibration from 60 to 70 mph
Old Dec 16, 2011 | 04:30 PM
great68's Avatar
great68
Default Vibration from 60 to 70 mph
Just had my motor put back in my 68 427 vett and was going home (40 mls) and about 8mls from the house I noticed a vibration that seem to be coming from the trans area. I seem to feel it in the shifter. Next day I took it out and I got about 6mls from home and again from 60 to 70 mph vibration got worse. So I drove it back to the house and parked it. Does not vibrate before 60 and after 70 its not as bad. It didn't vibrate until I got about 30 or so miles from the mechanic's. I think it's getting worse. So as soon as the weather gets better I am taking it back to the mechanic!! What could it be? (I know it could be lots of things but give me a few of them!) He did not remove the trans. New flywheel.
Old Dec 16, 2011 | 04:39 PM
gcusmano74's Avatar
gcusmano74
I am assuming you have a manual trans. Make sure the shifter was reinstalled correctly. Loose bolts on any of the brackets, or loose G clips on the shifter rods, can vibrate and buzz at certain speeds.
Old Dec 16, 2011 | 05:46 PM
great68's Avatar
great68
Yes it is a 4spd and I will check all the linkage and nuts and bolts. The mechanic said he didn't remove the trans, so would he have to remove the shifter?
Old Dec 20, 2011 | 04:42 PM
great68's Avatar
great68
Drove it down the road for about an hour taking it from 0 to 85 or 90nothing happened. Hit 60 to 70 no viberation. Push in clutch at 60 to 70 and no difference...seemed to try everything I could to make it vibeerate and nothing. So I guess I'll keep driving it until something else happens. Thanks to all!!!
To Vibration from 60 to 70 mph
