Winter project
Old Dec 17, 2011 | 03:08 PM
Ravoll's Avatar
Ravoll
Default Winter project
Hi Ya'll,
Cold and rainy here in "Good Old Germany",so I decided today to get started on my winter overhaul.
every thing is ready for pulling the motor and tranny as one,and have a question.
Should the radiator mount/crossmember be removed or will the
pullys clear with it in?
Don't want to have this thing hanging on the shop crane and run into problems.
Alan
Old Dec 17, 2011 | 03:56 PM
lonebull's Avatar
lonebull
I pulled my 78 small block & auto trans. recently but if I had to do it again i would separate the two. I had the radiator & shroud removed as well as the water pump. It barely clears & is at a pretty steep angle. Tie a towel over the trans shaft to reduce damage to the firewall. Mine wanted to drag on the firewall as I pulled it by myself. But yes- it will work.
