Installing LT1 into my C3
Looking for some help! I'm in the tail end of an LT1 swap into my c3 and I have run into some issues. Hoping you can help!
1. On the 93 LT1 motor i'm running the GM manifold with a Holly Carb. The stock hood is hitting the carb choke tower and there is no way to put on an air filter. Does anyone have any suggestion on a different intake or carb.
2. For the Power steering high presure line will the stock cable from the C4 work or do I have to make a custom cable.
3. Radiator hose. I used a top end hose from a 96 z28 and a bottom hose from a 96 corvette. It seems like the top hose goes into the water pump were the bottom hose should go and the bottom hose looks like it's going into the input. I know this is a reverse flow water pump. Does my set up sound correct. I'm using an aftermarket alumminum radiator.
