Ti ignition has weak spark
If I put a jumper from the plug wire to almost 1/8" ground. It will spark but not from 1/4" I went over the ground on radiator. Is there more grounds I"m missing?
Any ideas?
The engine ran a month ago but was hard to start then. Now it wont start at all.
I did clean up another ground on the amplifier itself still spark is so weak it wont even light the timing light
Does the stock system just have one wire each to the coil? A big white wire to the plus terminal and a smaller black wire to the neg?
Plus the coil is pretty warm just from me troubleshooting and turning the engine over..normal?
Looks like the proverbial "can 'o worms" to me. Hope you can get to a more knowledgeable source that can fill in the gaps and get you up and running.
You mentioned that the amplifier has been replaced/(updated?). I don't know if the circuitry has been modified or if parts have been updated to newer/better parts. Newer style parts are more durable, but it's best during testing to assume the module is still a delicate piece of electronics.
Is there only 1 wire on the neg terminal and one on the pos?
Thanks everyone for trying to help I need it!
What about the coil being pretty warm while I'm trying to get the system to work. Is that normal?
Please measure the voltage you have at the coil,
it should be around 7 Volts.
If you have this or higher voltage, the coil is the reason for weak sparks.
The TI-Amp has only 3 transistors inside (i mean the original unit from back then. Dont know newer circuits.).
The spark is generated by cutting off the voltage from the coil.
Well as your only problem is the a weak spark, i guess the distributor and the amp are working good. Cant imagine the amp pulls the coil only 3 volts down, what could also cause a weak spark.
But what is very important is, that you have the right polarization at the coil! If you twist it wrong, you will have less spark power.
Maybe you try this first, its no big deal to change the connections
If you have no spark afterwards, it was already right. If its stronger, you got the root cause.
Question 1 Is that 7 volts on the plus side of the coil while I'm cranking the engine or while I just have the ignition on?
According to ti specialty that voltage with just the ignition on should be 2.5 - 4.5. My car had 3 v
Question 2 You mentioned the right polarization of the coil. Are you talking about me putting the white big wire to the ground side and the black wire to the plus side?
Am I missing any?
4V seems to be to low, check if 12V coming out of the amp to the coil.
The difference gets lost at the resistor wire between them.
(i hope your car battery is loaded ;-) )
Next thing about the wiring of the coil: just make sure that the (-) negative marked conncetor is connected to the ground of the car.
Measure the voltage between the ground of the coil and the engine (ground). Ignition must be on.
If there is a drop higher than 1 volt thats not good. The (+) side of the coil must deliver a higher voltage against the engine block.
With this test you check for a good ground connection too.
And to come back to the 7 volts of the coil: this voltage depends not only on the supply voltage. (caused by ground or supply connection problems)
It depends also on the coil resistance!
If lower resistance, lower voltage will be measured because of a higher current that is more limited by the resistor wire before the coil.
Yeah its not that easy to find the root cause if you have no good electric background
