Dual post battery question
Internally the posts are connected together.
I ran my stereo off the top posts for a long time, no issues.
One word of warning though, if you run a battery disconnect and forget to connect it, or have a poor main ground (or power for that matter) it will try to pull through you stereo instead. Proper fusing is even more important than normal.
Also watch where your head unit and amp(s) ground so you don't end up with a loop.
(Louder exhaust will usually cure the problem)
What happens, in multi unit systems (head unit, amps, disc changers etc) is since they are all connected to each other (usually the RCA cables) and contact the car in different way(brackets etc) if one of the units (for some reason usually seems to be the head unit chassis ground) will be grounded to the chassis (dash bracket, etc) while something else is grounded directly to the battery or to a real good ground (frame or bracket near an actual ground strap). Electricity being what it is, tries the route of least resistance and starts using the inter-connecting wires to get to a good ground instead of the one you tried to give it.
You can sometimes see this when you disconnect the negative wire for the radio or amp and it still comes on (sometimes just faintly) as it finds a ground through the antenna wire or some other path.
By hooking all grounds to a common point, all units get the same potential and the unwanted flow between the units should be eliminated.
There are ground isolators out there but it's like fixing an electrical problem by putting a bigger fuse in.
Tons of info on ground loops available on the net (some people are rather obsessive about it so be careful)
Again, not an expert. Actual mileage may vary. Belly buttons.
