fiberglass spring help?
Presume you are wanting to use the spring on your 1978. The fact that it came off an 1980 (aftermarket - no OEM composite springs in 1980) would indicate it would not work on your 1978. A call to Muskegon might be useful.
http://www.muskegonbrake.com/v4/go.g...&listTemplate=
CASE CLOSED.....
does it have something like 602-??? for a part number? The TRW style had three boxes for the last three digits and one would have a hole punched in it to mark what the rate was
Mooser
CASE CLOSED.....
I had KYB shocks with a 360 lb VBP for years also and replaced the KYB shocks with Bilstein Sports. HUGE improvement.
any opinions on the TRW spring, and installing it on a 78? I am looking for improved ride, handling is not my main concern.
Thanks!
Edit: I am looking at a picture of this spring and got thinking..the reason one of the sets of numbers is unreadable is because it looks like there was a hole punched. I see TRW listed 3 springs. a 315, 340, 355 pound. Maybe because the second box is punched, it is a 340 pound? Any idea how this compares to stock?
Thanks!
Compared to stock? I think the stock 78 was around 260 or something. Problem is you can't really compare the steel to glass very well, seems like I see a lot of guys running the 315 on small blocks. I have a 355 on my BB.
The strange thing is that number seems to match the 68-77 springs, they list a different number for 78-79
Best to make sure it's the right one for the 78
Mooser
Thanks!
Thanks!
As noted above, switching from a steel spring to a fiberglass composite is not an apples to apples swap since the composite spring has much different rebound/compression characteristics compared to a steel spring. One of the advantages of using a composite spring (and there are many and the reason GM stopped using steel in 1982 completely) is that you can go MUCH higher on the spring rate with composite with a MUCH BETTER ride quality and handling characteristics versus steel.
In 1986, I purchased a VBP 360 spring (which I still have in the car) to replace the 260 # steel gymkhana spring and was shocked at the superior ride and handling characteristics of the 360 composite spring! In general, C3's IMO are sprung way too soft in the rear from the factory (probably due to the ride characteristics of the steel spring) and have way too much flex in the front and rear suspensions with the rubber bushings. The 360 spring with the appropriate shocks (I use Bilstein Sports in the rear only, HD's in the front with the 550 springs) rides much better than the steel 260 spring and has much better reaction time compared to the steel one. When and if I need to replace the 360 composite in the future, I will probably go with a 420 rear spring. Keep in mind that my current setup in the rear:
360 Monospring with poly cushings
Bilstein Sports
Competition adjustable strut rods with Heim joint ends (no bushings)
3/4 inch OEM type rear sway bar with poly mounting bushings
255/45/17 ZR Ultra high performance summer only tires
is superior in ride and handling characteristics to the OEM setup of:
7 leaf 260 steel spring
AC delco shocks
OEM strut rods with rubber bushings
7/16 inch rear sway bar.
255/60/15 S/T rated tires
Hope that helps!
CASE CLOSED.....
I saw a post I can't find again about which composite spring brand to use and what not to use. I remember there was a brand not to use.
Will the pounds change the ride height in the rear?
(I'm switching out my old 7 leaf in my BB 69)
