Squeal in clutch
Old Dec 28, 2011 | 09:29 PM
Dacer's Avatar
Dacer
2nd Gear
Default Squeal in clutch
The clutch on my '69 squeals in neutral and in gear until I depress the pedal just a bit, and then it stops. Any ideas?
Old Dec 28, 2011 | 10:13 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Throw out bearing going bad.
Old Dec 29, 2011 | 02:19 AM
Shark Racer's Avatar
Shark Racer
More likely, the clutch pivot stud or fork is worn.
A bad throw out bearing will make noise during clutch release, not with no load on the bearing.
Old Dec 29, 2011 | 10:03 AM
Dacer's Avatar
Dacer
2nd Gear
Thanks for the help. I'll try that.
Old Dec 29, 2011 | 12:42 PM
LT-1 kid's Avatar
LT-1 kid
it could also be the pilot bearing. either way trans has to come out
Old Dec 29, 2011 | 04:33 PM
my 76 ray's Avatar
my 76 ray
And while it's out, I would replace both of them. Neither is really expensive.
To Squeal in clutch
