hydroboost lines
Old Dec 29, 2011 | 02:59 PM
rugerm44's Avatar
rugerm44
Default hydroboost lines
In the middle of installing the kit and was wondering how you guys ran your lines.I'm thinking the line that gose to the control valve would run behind the ps pump and loop back under the motor mount bracket to the valve.Pictures and any better ideas on how to run it.I have a 71 small block with headers.Thanks.
Old Dec 29, 2011 | 03:42 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Here's a couple of currently running threads where pics may exist to give you some ideas:
http://forums.corvetteforum.com/c3-t...ing-sizes.html
http://forums.corvetteforum.com/c3-tech-performance/2942253-steering-change-over-jeep-or-borgenson.html
Old Dec 29, 2011 | 03:58 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I'll be interested in what others post as I've never been very happy with how my hydroboost hoses ended up. The return line in particular scares me.
Old Dec 29, 2011 | 06:56 PM
rugerm44's Avatar
rugerm44
I got the two pressure lines ran.I ran the one going to the steering valve parallel to the pump line and then looped it back to the valve under the motor mount bracket.Seems to work pretty good.I just ran out of steam.I replaced the pump,actuating cylinder,control valve and the factory lines today.I'm getting there.Haven't got to the return line yet.I have hydrobooster mounted on the firewall.I still have to bench bleed the wilwood mastercylinder and put it on.That was a lot for one day.I'm pooped.
Old Jan 18, 2012 | 01:45 PM
rugerm44's Avatar
rugerm44
Not much you can do about the return line.I installed it just like the instructions said.There's really no other way to install it.I finally got the kit installed.I bleed it yesterday.I'm going to bleed the brakes tommorw and see how it gose.
Old Jan 18, 2012 | 02:57 PM
pauldana's Avatar
pauldana
I have the hydro boost and steeroids r&p. YOU NEED to put in a seperat return in your ps pump resavor. If not in hard turns and simultaneous braking you will have problems.... I just got through modifying mine.... World of differance.... That "T" becomes restrictive in the return lines when both flow heavy, and you will feel it in both the steering and braking.... Also, I have found it nessary to mod the pump regulator to put out a higher volume of ps fluid to keep up with he flow... This is achieved by drilling out the regulator hole... It's not much... But makes a big differance.
Hope that helps.... P
Old Jan 18, 2012 | 06:11 PM
aussiejohn's Avatar
aussiejohn
Paul,
I do not doubt your comments at all, however, when I removed the low pressure return line from my HB I noticed the very small hole in the fitting. It's only about 1mm in diameter and must be a huge restriction in the return line. I'm amazed that having this line Teed into the single power steering return line would make that much of a difference.
I'm building my own reservoir with TWO inlets and will use both. I intend to mount it right in front of the Borgeson power steering box and run the return line from the box to the lower inlet and the return line from the HB to the higher one. I will be using -6 AN fittings and 3/8" lines for both. I believe I need to baffle the reservoir, any ideas on this?
The feed line from the reservoir to the pump (I'm using the small GM "metric" pump) will be -8 or half inch, maybe even -10. The position of the reservoir will give a straight run to the pump with minimum kinking of the feed line.
Can you tell me which of the two big fittings on the HB is the supply one?
Thanks in advance.
Regards from Down Under.
aussiejohn
Old Jan 18, 2012 | 06:19 PM
RobbSalzmann
St. Jude Donor '12
Thanks in advance.
aussiejohn
aussiejohn, The 18mm x 1.5 fitting takes the output of the ps pump. The drawing I have then has the 16mm x 1.5 as the output of the HB that feeds the input of the PSB. For me that means about an 8" line, which seems odd, because all the pictures I see have no short line running from HB to PSB. Hmmm
This is the resevior I'm planning to use. It came with one nipple inlet, so I added the second one and converted the nipple to AN. Kind funny looking I think.
Old Jan 18, 2012 | 06:20 PM
'75's Avatar
'75
Not my picture but it's a good one.
Old Jan 18, 2012 | 07:35 PM
pauldana's Avatar
pauldana
Paul,
Thanks in advance.
aussiejohn
uuahhhhh.... looks like you got your answer!!!:flag :
Old Jan 19, 2012 | 05:11 PM
aussiejohn's Avatar
aussiejohn
Default Thanks guys.
'75,
That's exactly what I was after, thank you. I'd love to fit all braided stainless hoses, but will stick with the stock rubber lines at this stage - I just want to get it back on the road. A good friend Chris works for Hydraulink, and will help me out with the fittings and will assist with getting all of the correct ends fitted to the hoses. I will re-use the year old Borgeson hoses that are connected to the steering box, but will have the other ends fitted with AN fittings for connecting to the HB and the fluid reservoir.
Robb Salzmann,
I have concerns about your fluid reservoir. Jim Shea told me on this Forum that the fluid return lines should enter the reservoir down low, under the fluid level. He said that this will minimise aeration of the fluid. I'd seek his counsel before proceeding with this system.
aussiejohn
Old Jan 19, 2012 | 05:32 PM
mrvette's Avatar
mrvette
I NOT commenting about racing use, but the above is rong....I have run HB for over 5 years of quick daily driving with my own rack install that is 10 years old now...and have a 3/8 T in the return line...
never an issue...the addition of extra returns to the res is a time waster AFAIK....
NOW, I am using a '88 vette pump with '72 vette valving on the output...and so the plastic res. is just below the master cyl on the frame but WAS on the A arm cross support...
Old Jan 19, 2012 | 06:47 PM
pauldana's Avatar
pauldana
I would always want as much "headroom" in my vetts abilities as possible. Where I first got this information was from a tech at Steeroids. Hey said it is not always required but will fix the problem if it arises. So, if you are happy with what you got....
I do race at willow springs "streets of willow".....and yes, in hard on the brakes and hard on the steering.... so i want everything i can get...
thus...if your taking time to do a job, try your best to do the job right the first time....
Old Jan 19, 2012 | 09:17 PM
rugerm44's Avatar
rugerm44
I bleed the wilwood mastercylinder and brake calibers today.All my headaches went away.I had too much pedal travel with the brand new vaccum booster and factory new mastercylinder.Never could get proper pedal travel.It would go to within and inch of the floor and it would be a fairly hard pedal.You could lock up the brakes but it was a little un nerving to say the least.Locks up the brakes with less than an inch of pedal travel.Best money I ever spent.At least I can drive it now without worrying about if I'm going to stop or not.Haven't noticed anything about performance when brakeing in a turn yet.It seems to work fine considering I havent put the suggested 500 miles on it yet.Just around the block.
Old Jan 20, 2012 | 09:39 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
rugerm44, good to read you found some joy. Just adding my .02 for images.
I don't know that mine are run better but I'm happy to share what I did. Referencing the graphic from Robb's post #8 above as my model at the time, also, I have the low pressure hose run adjacent to the braided high pressure lines down to a 3/8" brass T. The low pressure hose drops over the top of the driver side motor mount into the tee.
FWIW: have never experienced any loss of braking or steering performance driving over 15K miles with occasional, spirited exhibitions.
Excusing the grime, I happened to take these images just a few days ago:
Looking down, from behind the firewall: I used 2 hose clamps for the braided lines, otherwise, they are laying where I strung them.
Hope that helps anyone who may consider using a HB. Love mine.
Old Jan 20, 2012 | 10:17 PM
rugerm44's Avatar
rugerm44
Thanks for the info.Right now I ran the return next to the pressure lines.They curve close the the rear upper a frame bushing and then go straight down to the back of the pump.So far so good.Nice to finally have a,hard pedal without the excessive travel.I have been fighting with this thing off and on for over a year.With the factory calibers and booster I always had way too much travel before the brakes locked up.Not to mention all that brake bleeding and it never got better.It took 20 minutes to bleed the brakes after I installed the hydroboost and the new wilwood mastercylinder.I can't put into words just how frustrating it was.Now I can move onto other things I wanted to do to the car.
Old Jan 20, 2012 | 10:40 PM
noonie's Avatar
noonie
I have a GMC 1 ton with factory hydraboost and it has the 2 factory return lines into the pump reservoir (posted pics here before) and there are times when the brakes are applied that the steering becomes very jerky, not often but it does happen. Gm had 2 lines for a reason.
Keep in mind that the brakes are usually applied when the engine and steering pump are at the lowest rpm.
To hydroboost lines
Old Jan 21, 2012 | 12:53 AM
pauldana's Avatar
pauldana
yup.... thats what im talking about.... 2 lines needed
Old Jan 21, 2012 | 11:10 AM
RobbSalzmann
St. Jude Donor '12
Robb Salzmann,
aussiejohn
AJ, Once again you are spot on with your observations and advice. I may just go get some stainless sheet and fab one up from scratch, using Jim's design requirements.
Robb
Old Jan 21, 2012 | 12:13 PM
CA-Legal-Vette
Just to add a little to the posts above, I plumbed mine very much like Dustup did, but I don't have the Flaming River U-joint in my steering linkage. I still have my stock rag joint. The rubber return line comes AWFULLY close to the joint and I've never been happy with it. I would recommend the right angle fitting that '75 posted in his pic above.
