Vac. switch
Old Dec 31, 2011 | 03:54 PM
bschuus's Avatar
bschuus
Default Vac. switch
I have an 80 vette. I was wondering the vac. switch on the firewall with 2 wires. I was wondering if thats for the trans overdrive or something. I'm in the process of removing the majority of the vac switches and hoses. Does anyone kno what will happen if that switch is disconnected.
Old Dec 31, 2011 | 09:05 PM
'75's Avatar
'75
I believe that switch controls the lock up clutch for the torque converter if you have TH350C.
Old Jan 1, 2012 | 11:01 AM
bschuus's Avatar
bschuus
What do you think if i ran a vac hose from the carb to that? because the original line t's off at the charcoal canister and then back up to one of the fittings that is on the intake coolant passage/thermostat housing. Who knows if that stuff even works after 30yrs anyway. Thanks for your input.
Old Jan 1, 2012 | 12:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bschuus
...Who knows if that stuff even works after 30yrs anyway...
What's your RPM on the interstate? If it's normal, the torque converter is locking up and you do not have to re-engineer anything under the hood.
Old Jan 1, 2012 | 03:58 PM
bschuus's Avatar
bschuus
I will double check the rpm's but I think they are around 2k at around 55. I haven't been out yet since I started removing the emissions stuff. Thanks
Old Jan 1, 2012 | 04:47 PM
mapman's Avatar
mapman
Welcome to the Forum!
Page 7A-3 of the 1980 Shop Manual shows the fender mounted vacuum switch closing at 7 inches HG and opening at 2.5 inches HG. Not sure how that compares to a vacuum line off your carburetor as their are several ports.
Are you removing the charcoal canister? IMO removing the charcoal canister will also require modification of the gas tank/vapor lines and gas cap as well.
Old Jan 1, 2012 | 05:31 PM
doctorgene's Avatar
doctorgene
Yes Sir; The vacuum to the transmission switch, runs from the front of the carb. to the switch, then two green wires are at the plug in. one goes to under the dash. There are two from the transmission, Green one goes to the switch, the other green splits going under the dash & up to the switch. I need the plug end for mine if you take yours off. Have a great one. Gene
Old Jan 1, 2012 | 06:54 PM
bschuus's Avatar
bschuus
I guess nothing is that easy. I will leave the charcoal canister and try and find a port on the carb that will give me the correct vacuum I need.
To Vac. switch
