Ryan's Small Block Engine Dyno's
Old Jan 2, 2012 | 07:50 PM
gdh's Avatar
gdh
Default Ryan's Small Block Engine Dyno's
I post this link every few yrs. It is getting a little dated now but still a good reference source.
http://www.ryanscarpage.50megs.com/combos1.html
Old Jan 3, 2012 | 11:07 AM
69 Chevy's Avatar
69 Chevy
109 combinations and yet you can count on one hand those with listed max horsepower over 6000 rpms. Makes me wonder if all the folks with 10 grand tachs are overly optimistic?
Old Jan 3, 2012 | 11:31 AM
Shark Racer's Avatar
Shark Racer
I had a 10 grand tach in my truck... didn't come from the factory with a tach, so I wired it in.
4-speed big block (460) Ford.
Anything over 4k was torturing the poor thing.
Old Jan 3, 2012 | 11:44 AM
scottyp99's Avatar
scottyp99
When I was in high school, a friend of mine installed an atermarket tach in his GTO, and was all exited to show me how his engine would rev to over 10,000 rpm. The knucklehead had it set on 4 cylinder mode!!!!!
Even after I told him about it, he decided to leave it that way, 'cuz he thought it was cool!!!!
Scott
Old Jan 3, 2012 | 11:52 AM
nate99's Avatar
nate99
This is a great resource that answers so many power questions. Thanks for posting the link.
Old Jan 3, 2012 | 12:00 PM
scottyp99's Avatar
scottyp99
Yes, it's a little dated, but the sheer volume of data all in one place is incredible!!!
Scott
Old Jan 3, 2012 | 12:15 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That is a great resource I have linked many times. The biggest problem I see in using it is the fact that the majority of corvettes come with a 3.08 rear gear that is about useless with the high HP combinations. Many first timers want the big power numbers without taking into cosideration that the gearing in their car will not match up well to the engine power band. This is a common rookie mistake and many spend the big bucks on the high horsepower and are disappointed in the performance and streetability once it is in the car.
Old Jan 3, 2012 | 12:44 PM
nate99's Avatar
nate99
I'm working to get good info for what will make the best combination for a torque converter and gears on my GMPP 290HP crate. I'm fairly sure that stock stall and 2.87's will be underwhelming. So far I'm leaning towards a 2000-2200 ish stall and 3.54 gears knowing that it will be spinning quite high on the highway, but that's way down the road, so I'm sure I'll change my mind between now and then.
Old Jan 3, 2012 | 12:47 PM
scottyp99's Avatar
scottyp99
I don't think there was one engine that had it's torque peak below 3500 rpm. I have a 3.07 diff, and I'm installing a 700r4 tranny to crutch the diff ratio, but with the wide gear spacing, you still need a broad torque curve. It's all about trade-offs, I guess.
Scott
Old Jan 3, 2012 | 03:09 PM
7T1vette's Avatar
7T1vette
I didn't search through all the combinations...but did any of those builds use a Q-Jet, just to see if there was any difference between the Q-Jet and a Holley 750?
Old Jan 3, 2012 | 03:28 PM
scottyp99's Avatar
scottyp99
Yeah, there are a few examples where there are 4-5 different engines, but they are part of a series where they did upgrades and dyno'ed the results, I don't think there are any where that's the only change, tho. if you view the list as an excel spreadsheet, you can very quickly schroll down and see which motors use a Q-jet.
Scott
Old Jan 3, 2012 | 03:37 PM
billla's Avatar
billla
St. Jude Donor '14
It's all about matching the right pieces to find balance - especially in a C3. Not just the gears, but the overall use of the engine...and matching it with ensuring the chassis, suspension, brakes and tires are up to the challenge of newfound power...making sure it's "fit for purpose" - matched to how the car will be used.
To Ryan's Small Block Engine Dyno's
