DIY GA Rack Install
Kal
Save yourself a lot of fabrication, pain and time and spend about $700 and buy a Borgeson integral power steering box. It comes with a three year written warranty and is made in Torrington CT. Although derived from the Jeep, each box is stripped, machined, has a Corvette-specific mounting plate welded to it and rechecked and re-machined if necessary. The sector shaft is re-splined to suit your original Pitman arm, so all factory steering linkages are used. No bump steer!
It is then assembled to better than factory tolerances and sold with the above warranty. When fitted, you will have a much friendlier 12.7:1 ratio, and a variable boost just like you'll find in a modern car. The further you turn the wheel, the more boost you get, but in a straight line driving situation, you get almost none, and can feel the road a whole lot better than the factory "power" steering ever gave you.
Seriously, is it really worth it to worry about how strong the brackets need to be for an inferior R&P set-up? And most R&P kits are centre take off, so they WILL give you bump steer. The Borgeson box bolts in using the factory mounting holes and uses ALL of the factory tie rods, idler arm, drag link, Pitman arm, etc. Plus, it will clear any factory exhaust and almost all aftermarket headers.
Finally, if you're a good mechanic or know one, the whole job should take just an hour or two to fit, especially if you have a hoist at your disposal. Ring Jeff or Gil at Borgeson on 1-860-482-8283 or sales@borgeson.com if you want any more info.
Regards from Down Under.
aussiejohn
Kal
There are several threads on rack and pinion installation, but this one should have what you are looking for. There are no templates to copy, but a good example to follow. Reverse build the install and make your own bracket templates after the rack ends are connected. I'm sure Riggs will be happy to answer any questions you may have. Good luck!
http://forums.corvetteforum.com/c3-t...nd-pinion.html
[/IMG]
