which engine?
As for the gear I suggest. I think either of these engines will be torquey enough to go a little higher on the gear in order to retain a little highway tolerability. I would go with the 3.55....unless you almost never take it on sustained 65 or 70 mph drives. There is a trade off. For everything you gain on the low end, you will lose on the top end. If you almost always drive around town at 55-60 or below, I would go with the 3.70.
dl
When you start changing things you become the chief engineer/designer.
You also need a trans. cooler for the converter.
Your current Engine operating rpm range starts at idle.
3000 IS NOT HIGH RPM that is basically just in the beginning of the operating range of those engines.
You need to state what your design para. are. For ex. would you like 427-435 HP performance, gas milage,..
I am still looking over these engine choices. I can't get past the fact that when taking what you are after either of these engines is complete and utter OVERKILL. You are going to end up spending a bunch of money and the end result is going to be way more than what you have stated that you want out of this car. I stated earlier that everything with performance mods is a trade off. You have to be very specific and true to yourself when defining what you want because the more radical you go, the less streetable it will be....PERIOD. Now I am going to do what you asked us not to do.....I would really suggest a ZZ4. There is a reason why all the guys on this board think so much of these engines. They are great turn key engines at an affordable price and come with a warranty. Can't beat that. And that engine will be such a step up from what you currently have that you will think you have a big block under the hood.
I just don't want to see you get into this and spend a lot of money and the car end up not being what you envisioned.
Just remember I am trying to help. :yesnod:
dl
Just food for thought. Oh, and the price is under $3,800.
dl
If we can't talk you out of the radical setup, here's what I would change from stock to accomodate either of these engines:
1. 2500 stall
2. 3.55 gear at least
3. 1.75" primary headers
4. At least 2.5" exhaust with low restriction mufflers
5. Stock cooling system with dual electric fans thermostatically controlled
6. Trans cooler needed with a stall converter
7. Replace all u-joints with heavy duty with no zerk fitting provision
8. Upgrade ignition -- hotter coil, good wires, etc.
I'm sure I am forgetting something but maybe Ganey or others will chime in.
As I said before, when making a siginificant engine upgrade, there are a lot of things that have to be addressed to improve longevity and performance. It's a total package with everything working in unison. There is more to it than just dropping a new engine in. As for reliability, it won't be as reliable as stock. A performance setup never is. It is just inherently harder on parts. ALL parts. Not just engine parts. The rear suspension of your car needs to be up to the task of handling significantly more torque.
Just don't want you to bite off more than you can chew with this. Hate to beat the dead horse but go with a less radical setup and many of these mods are unnecessary and/or could be done over time.
I am only trying to help you and believe me, I once built a "street" car that I found out after it was done and had a ton of money in that I couldn't drive it on the street. It burned a gallon of gas in 6 minutes idling while I was setting the timing and adjusting the carb. The car ran great!!!!! I ended up getting it into the very high 10s in the quarter and I absolutely couldn't drive it on the street. Couldn't even drive it to the track. So take it from somebody who knows first hand.
dl
Erika - set a realistic budget for an engine say $3500 and then add $1200 or so for trans work for a monster, 250 for a converter and $1000 for the rear end.
Paul:cool:
What we are trying to say is your car won't be all that fast at the take off but will really rock and roll once it gets going. However on the street many times the race is over before you'll get into your power band. Plus you might not be able to spin your tires from a take off :cry.
So as mentioned earlier you will have do all the little tricks, (stall, etc..) to make it bad off the line.
If you get the proper set up then I wouldn't be scared to put in the bigger HP motor. We are just trying to give you a heads up so you won't be dissapointed but verrry happy and know what to expect.
We would like you to be happy w/ it as well. There are inside jokes that start "You know you went to far when..." Your future topics on that is what we are trying to avoid. We would like you to be happy w/ it.
:cheers:
