Lock Up TC
Old Jan 6, 2012 | 08:45 AM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
Default Lock Up TC
I have a lock up transmission with a 2 prong plug. I have the cable for it but can't find where to plug it on the car (81 Vette). The cable is two prong but only has one wire and the end that plugs to the car is a one prong round plug with a flat contact surface. Any help will be appreciated.
Old Jan 6, 2012 | 09:59 AM
7T1vette's Avatar
7T1vette
The converter lockup for the '81 C3 was controlled by the ECU. You will have to get a detailed schematic to hook it in...IF you still operate with that ECU. If not, you will need to purchase a lockup 'controller' and wire it up with a disconnect switch on the brake pedal.
