How do I get the ball joints out?
Old May 11, 2002 | 09:57 PM
mixtli's Avatar
mixtli
Default How do I get the ball joints out?
Ok, so now the control arms are out, and I figured out how to get the bushings out. Now I can't get the ball joints seperated from the control arms. I ground the heads of the rivits off (the side with grease fitting) and looks like they should come off now, but not budging????
What am I doing wrong?
Thanks,
Bob
Old May 11, 2002 | 10:03 PM
MIKER's Avatar
MIKER
Default Re: How do I get the ball joints out? (mixtli)
The typical response to this question is get a BIGGER HAMMER. That's what I did. :smash:
I suppose that you could also have it pressed out.
Old May 11, 2002 | 10:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: How do I get the ball joints out? (MIKER)
Get an assortment of drill bits and use the smallest one and drill the center out. Move up to a larger size and drill down the center of the rivet. Keep this up and soon you will have removed your ball joints. Just did it this way about a week ago.
Old May 11, 2002 | 10:48 PM
Sean Willard's Avatar
Sean Willard
Default Re: How do I get the ball joints out? (Eddie 96)
Yep ball joints are a PITA, I helped a friend do his recently we end getting them out the same way Eddie just described. We beat on them first for a day or so after we'd ground off the rivits with no luck :smash: . Just be patient and drill them out carefully. Good luck. :cheers:
To How do I get the ball joints out?
