Heater Control Replacement
Old Jan 20, 2012 | 06:17 PM
DonW's Avatar
DonW
Default Heater Control Replacement
I'm in the process of replacing my heater control, no A/C. Can I use a heater control from an A/C car and switch over the plates? I read Willcox' paper on the rebuild and he notes that the controls are manufactured in the same manner but I wanted to make sure there weren't any issues with the swap.
Old Jan 20, 2012 | 11:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
What year is the car? your profile said 66??
Old Jan 21, 2012 | 04:15 AM
7T1vette's Avatar
7T1vette
Well, there are several parts in that gizmo that are different between the A/C version and the non-A/C version. The vacuum distribution manifold is different, there are A/C switches that won't be utilized. I'm sure the faceplate is different.
But, I don't have a firm grasp on exactly all the differences and whether one can be converted to the other easily...or not. My first recommendation would be to just refurbish/rebuild the one you have with only those parts that require replacement. The detail parts are mostly available from the Corvette parts vendors. Once you get it apart, you can determine what is not working correctly and repair from there. Just my 2 cents....
Old Jan 21, 2012 | 07:33 AM
DonW's Avatar
DonW
I currently have a 1972 non-A/C conv.
Old Jan 21, 2012 | 07:39 AM
DonW's Avatar
DonW
In reply to 7T1Vette I am in the middle of a complete resto. I took out the control and most of the guts and switches are good except the thumb wheels, strings, and the small grommets the strings are wound around. Someone had been in there before me and did some weird jury rigging. Anyway I can get a cheap 72 controller for an A/C car and wanted to make sure I can swap in the main section with the thumb wheels and strings intact and use my switches and face plates. Thanks for the help.
Old Jan 21, 2012 | 10:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can get a restoration kit for your stock control. Replaces the wheels, guides, strings, etc.
AC and non-AC controls are not the same.
Old Jan 21, 2012 | 11:12 AM
Maymyvetteliveforevr's Avatar
Don't mean to highjack but does anyone have the routing diagram for the string that goes around the rollers?
Old Jan 21, 2012 | 11:27 AM
0Willcox Corvette
Former Vendor
When that paper was written, I don't believe the entire kit was available for the non ac cars. However it is now and around 77.00 (use the sale code and save more)
http://willcoxcorvette.com/product_i...oducts_id=6816
The wheels, and all the small parts like the pointers, the strings and wheels and so on are the same. The brackets are the same on the sides... but that is where it ends. The face is different, the vacuum select switch and the heater blower switch.
The kits are around
Old Jan 21, 2012 | 12:09 PM
DonW's Avatar
DonW
Thanks Willcox. Can you tell me where to find the sales code?
Old Jan 21, 2012 | 12:12 PM
0Willcox Corvette
Former Vendor
tenpercent
Old Jan 21, 2012 | 02:39 PM
DonW's Avatar
DonW
Thanks Willcox. Order placed.
To Heater Control Replacement
