Driver front really bad wobble
Old Jan 21, 2012 | 02:12 PM
zambo75's Avatar
zambo75
Default Driver front really bad wobble
Wobbly front drive wheel on my 75 c3.No pulling run straight feel like its trying to staighten out around 50 MPH replaced the rotor,blance the wheel.Sombody said its the spindle?Any other idea.or just take it a front end shop.
Old Jan 21, 2012 | 03:22 PM
fugawi's Avatar
fugawi
could be bearings, could be ball joints,could be more things. but a bent spindle is unlikely. find a good shop that you trust if your not repairing yourself.
Old Jan 22, 2012 | 06:34 PM
Stoge's Avatar
Stoge
Why do you say it is wobbly? Have you jacked the wheel up off the ground and rotated to notice a wobble, or can you just feel it when driving?
If the latter, I'd swap your front and rear tires on that side and see if the wobble moves to the back. Could be something as simple as a slipped belt in a tire or out of balance.
Old Jan 22, 2012 | 08:39 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Check the frame mounts for the lower control arms. Don't ask me how I know...
Old Jan 23, 2012 | 12:54 AM
RebarIV's Avatar
RebarIV
Something to think about would be the bushings on the upper control arm. I had a bolt back out of one on mine(drivers side), bushing popped out & reared its ugly head at 90 mph on the highway. They were "newly replaced" when i bought the car in march. However, it made my car sway back & forth really bad. Thought i was gonna lose control. Pretty sure the wife almost lost control too, of her bowels.
Old Jan 23, 2012 | 08:56 AM
birdsmith's Avatar
birdsmith
There are seven (7) locations where movement can take place ate either corner of your car's front end. Two at the inboard end of either control arm, one each at the outer end of each control arm, one at each end of the tie rod, and the spindle/wheel bearing. Looseness at any of these will potentially cause the 'wobbling' that you're noticing. An imbalance in the wheel normally causes the tire to 'bounce' vertically; no 'wobbling' or side-to-side motion.
To Driver front really bad wobble
