Engine swap
Old Jan 21, 2012 | 07:10 PM
Tommy8770's Avatar
Tommy8770
Default Engine swap
Looking at a 1976 with a 350 motor and transmission. To put a 454 or a 502 into the car will it go in without cutting for more room.
Old Jan 21, 2012 | 07:24 PM
72LS1Vette's Avatar
72LS1Vette
They will fit. 454 was an option for a number of years. There might be an issue of deck height as I think the truck blocks had a higher deck height. The other problem is exhaust headers but you can either find commercially built ones or have some custom fabricated. You will need a new hood also. You may also have to hunt for accessory brackets.
Search the forum for something like 'big block' and you will probably come up with lots of info.
Rick B.
Old Jan 21, 2012 | 07:32 PM
Tommy8770's Avatar
Tommy8770
Hey thanks for the info. The last swap I did was a 1979 chevy pick up with a 6 cylinder and 3 on the tree. I put a 350 engine and trans in it from a 73 gmc. It was very little trouble. Even used my drive shaft without having to change the length of it.
Old Jan 21, 2012 | 07:49 PM
milo30's Avatar
milo30
I researched it not long ago. The engine compartment is the same. Size won't be an issue. It's all of the littles that add up. Radiator, brackets, etc. People selling the BB corvette brackets are proud of them. Might be able to buy a serpentine system cheaper.
Be prepared to spend more than what you have allowed in the budget for the engine itself. If the budget isn't a problem then swapping for a BB isn't either.
Old Jan 21, 2012 | 10:17 PM
uxojerry's Avatar
uxojerry
Lots of engine builders are getting up to 454 on SBC builds, and up to 502 using the newer tall deck blocks. Take a look at ultrastreet.net for some examples. I bought one of their motors and was very happy with the whole process.
Old Jan 21, 2012 | 10:32 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you do the BB swap, stick with the standard 9.800" deck height. As mentioned, the swap itself isn't difficult if you have the budget.
Old Jan 21, 2012 | 10:33 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
To install a bb into a sb car you will spend probably $1200 in brackets, pulleys, oil pan, water pump, front springs because they're corvette specific. It's a drop in installation but you need the right parts.
Old Jan 22, 2012 | 07:51 PM
Tommy8770's Avatar
Tommy8770
Looked at the ultra street site and wow very impressive. Staying with a big small block looks like the ticket. Price of the motors for the $ looked reasonable for what you were getting. You say you used their motors with good results? Thanks for the input.
To Engine swap
