mid to high speed vibration....
Old Jan 22, 2012 | 11:27 PM
joedapro's Avatar
joedapro
Default mid to high speed vibration....
im feeling a vibration at 50 mph and up. in past exp, this has often been universal joint issue. havent had this L82 1980 model long, and although i have changed oil, and performed other regular maintainence, i have not checked rearend gear oil. it does have a slight clunking when shifting into gear, especially into reverse. any thoughts? i have changed email addresses, but havent changed it on here yet. im fixin to. my new email is joedapro@comcast.net. thanx guys
Old Jan 23, 2012 | 08:51 AM
fanmanbd's Avatar
fanmanbd
Where do you feel the vibration? Steering wheel, shifter or seat of the pants? That will narrow down the the possible problems a little.
Old Jan 23, 2012 | 11:18 AM
7T1vette's Avatar
7T1vette
Tire/wheel balance problem, most likely. The 'clunk' when you put it in gear is probably worn-out/rotted rubber cushions on the differential mount.
Old Jan 23, 2012 | 11:27 AM
joedapro's Avatar
joedapro
I feel it in the pants. About 2 weeks ago i may have flat spotted my tires a little though
Old Jan 23, 2012 | 11:28 AM
joedapro's Avatar
joedapro
I will check all mounts. Thanx
To mid to high speed vibration....
